3 Replies Latest reply on Aug 14, 2007 10:42 AM by kglad
    removing dynamically created movieclips
      i'm adding a movieclip from the library to the stage, then moving it with the Tweener class and finally want to remove it when all is done. As you can see from the code i'm getting a trace when i get to the removeClip() function that i made, everything works up to here. I'm just not sure how to use removeChild and how to identify the instance that is created by addChild. Any help would be brilliant
