3 Replies Latest reply on Jun 13, 2010 5:22 PM by mlabriola
    Issues with adding FlexUnitTestRunnerUI to FlexUnitCore
    abeymg
      Hi
      I am trying to create a test runner app with both a CIListenter and a UIListener. For the UIListener I am trying to use the FlexUnitTestRunnerUI, however when I try to use it as shown in the SampleCIProject I get the following compilation error:
      Description Resource Path Location Type
      1067: Implicit coercion of a value of type flexunit.flexui:FlexUnitTestRunnerUI to an unrelated type org.flexunit.runner.notification:IRunListener. ConsumerTests.mxml /PlayerDesktopTests/src line 30 Flex Problem
      Looks like an API change somewhere. Any ideas?
      Thx
      - abey
         xmlns:mx="library://ns.adobe.com/flex/mx"
         minWidth="955"
         minHeight="600"
         xmlns:flexui="flexunit.flexui.*"
         creationComplete="onCreationComplete()">
      <fx:Script>
      <![CDATA[
      import modelTestSuite.ModelTestSuite;
      import org.flexunit.listeners.CIListener;
      import org.flexunit.listeners.UIListener;
      import org.flexunit.runner.FlexUnitCore;
      public function currentRunTestSuite():Array
      var testsToRun:Array=new Array();
      testsToRun.push(modelTestSuite.ModelTestSuite);
      return testsToRun;
      private function onCreationComplete():void
      var core:FlexUnitCore=new FlexUnitCore();
      core.addListener(new CIListener());
      core.addListener(new UIListener(testRunner));
      core.run(currentRunTestSuite());
      </fx:Script>
      <flexui:FlexUnitTestRunnerUI id="testRunner"/>
      </s:Application>
        • 1. Re: Issues with adding FlexUnitTestRunnerUI to FlexUnitCore
          mlabriola Level 4
          That won't work.You are trying to use the FlexUnit1 TestRunnerUI directly as a listener in FlexUnit 4.
          A version of that old runner has been adapted to work with FlexUnit 4, but it is a different class altogether.
          I think this is what you are looking for. Note the differences in namespace and class.
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml"
          creationComplete="runMe()" xmlns:adobe="http://www.adobe.com/2009/flexUnitUIRunner">
          <mx:Script>
          <![CDATA[
          import compilationSuite.SuitesToRun;
          private var core:FlexUnitCore;
          public function runMe():void {
            core = new FlexUnitCore();
            core.addListener( new CIListener() );
            core.addListener( uiListener ); //(You also shouldn't need that extra layer of wrapping the TestRunnerBase in a UIListener first)
            core.run( compilationSuite.SuitesToRun );
          </mx:Script>
          <adobe:TestRunnerBase id="uiListener" width="100%" height="100%"  />
          </mx:Application>
          HTH,
          Mike
          • 2. Re: Issues with adding FlexUnitTestRunnerUI to FlexUnitCore
            abeymg Level 1
            Thanks for the reply. I assumed FlexUnitTestRunnerUI was the new FlexUnit4 test runner because, that's what FB4 automagically created.
            In any case, looks like FlexUnitTestRunnerUI automatically registers as a listener to FlexUnitCore, because I was able to achieve my objective by using the following:
               minWidth="955"
               minHeight="600"
            <fx:Script>
            <![CDATA[
            return testsToRun;
            </fx:Script>
            </s:Application>
            • 3. Re: Issues with adding FlexUnitTestRunnerUI to FlexUnitCore
              mlabriola Level 4
              i am sorry. i misread your code from my phone the first time. the class adobe includes is a bit weird. it isnmt really a runner or a listener. it instantiates a core and a listener internal to the class, but doesnt expose either.. making it a pain.
              i am trying to get adobe to change that
              as an fyi, if you took the code i provided and add an xmllistener to the core, it would also push the restults back to builder. in the end, adobes class, is their ui, an instantiation of the core, and the xmllistener composed
              mike
