2 Replies Latest reply on Jul 7, 2006 1:56 PM by Newsgroup_User
    CFIF inside a SQL statment
    Level 7
      I have a search page that has 3 possible entries. Service, City, & Keywords.
      Service and City are list/menus and cannot be null, but Keywords is a text
      box and can be null.
      I need to write a SQL statement to take the 3 possible parameters and test
      them against the database. Since the first 2 are never null, I can write
      them right inside the SQL string, but how can I only check for the keywords
      if there is something inside the box?
      Can I use a <cfif> statement inside the sql string to only check the 3rd
      parameter if it is not NULL?
      I wrote this:
      Select company, name, phone, city, state, username FROM members WHERE
      city = Form.City AND state = Form.state AND keywords LIKE Form.keywords
      ORDER BY company ASC
      Also, since I am passing it from a search page to a results page, would it
      be URL.City verses FORM.City, etc.
      Also would like to do this in a component and pass the 3 variables as
      arguments with the city and service being required and the keywords not.
      However, I have no idea on what the procedure is for this.
      I wrote:
      <cfcomponent>
      <cffunction name="ServiceSearch" access="remote" returntype="query">
      <cfargument name="service" type="numeric" required="true">
      <cfargument name="city" type="numeric" required="true">
      <cfargument name="keywords" type="string" required="false">
      <cfreturn ServiceResults>
      </cffunction>
      </cfcomponent>
      Do I invoke the component from the results page?
      Well, I need to solve the first issue before I attempt the second. Thanks!
      Wally Kolcz
      Developer / Support
      ProjectProofing.com
        • 1. Re: CFIF inside a SQL statment
          Level 7
          Actually, my component looks like this: (I forgot the cfquery..lol)
          <cfcomponent>
          <cfargument name="service" type="string" required="true">
          <cfargument name="state" type="string" required="true">
          <cfquery name="ServiceResults" datasource="#Request.MainDSN#">
          service = Form.service AND state = Form.state
          <cfif Form.keywords NEQ "">
          </cfif>
          </cfquery>
          </cffunction>
          </cfcomponent>
          • 2. Re: CFIF inside a SQL statment
            Level 7
            Yes you can put <cfif ...> statements inside a <cfquery...> tag to
            modify the SQL string.
            WHERE this = that AND
            <cfif len(trim(form.something))>
            AnotherThing = '#form.something#'
            </cfif>
            Is valid.
            Whether the form variables on the action page are URL or FORM depends on
            the method of your <form ...> tag. method="post" creates form variables
            on the action page, method="get" creates URL variables on the action page.
            You write <cfargument ...> tags for each argument you want to pass into
            a function.
            <cfargument name="city" required="true" ...>
            OR
            <cfargument name="foobar" required="false" default="" ...>
            You then use these in the function with the arguments scope.
            #arguments.city# and #arguments.foobar#
            You then pass these into the function from your calling page. There are
            numerous ways this can be done, here are a few.
            <cfinvoke .... city="Sacramento" foobar="george"/>
            <finvoke ... >
            <cfinvokeArgument name="city" value="Sacramento">
            <cfinvokeArgument name="foobar" value="george">
            </cfinvoke>
            <cfset myComponent = createObject("component","my.component.path.andName)>
            ...myComponent.aFunction("Sacramento","george")...
            ...myComponent.aFunction(city:"Sacrament",foobar:"george")...o
            > I wrote this:
            > I wrote:
            > <cfcomponent>
            > </cffunction>
            > </cfcomponent>
