> CF8 IIS6 fails
On this CF instance, browse to the template using the
in-built JRun
webserver instead of IIS. Does the flushing (!) work? This is
a fair
low-impact reconfiguration (if any at all), and quickly will
demonstrate
whether it's IIS or CF at fault.
To throw the cat amongst the pigeons, I've also see flushing
not work on
one CF7 machine where another with "identical" set-up (same
CF, OS, web
server config, set up by the same person, at the same time)
and code works
fine. Unfortunately the one that works fine is our QA server.
The one not
working is the client's live server :-(
That said, I've never thought it to be a CF problem, I've
always assumed
it's some sort of caching or transmission hold up from the
web server, or
intermediary network equipment.
Adam
