3 Replies Latest reply on Jun 15, 2010 7:44 AM by kglad
    hitTest trying to stop something moving
    DOMIN8ER258
      ok here is the scene
      _root.playa
      _root.playa.feetMC
      _root.corneria
      _root.corneria.limitsMC
      Now, what I want is when _root.playa.feetMC hits, or is ontop of _root.corneria.limitsMC it stops moving
      To help here is the code for my playaMC to make hime move
      onClipEvent (enterFrame) {
          movement = 2.5;
          if (Key.isDown(Key.DOWN)) {
              if (Key.isDown(Key.RIGHT)) {
                  movement = 0;
              if (Key.isDown(Key.LEFT)) {
                  movement = 0;
              this.gotoAndStop(1);
              _root.playa.downMC.play();
              _root.corneriaMC._y -= movement;
          if (Key.isDown(Key.UP)) {
                  movement = 0;
                  movement = 0;
              this.gotoAndStop(2);
              _root.playa.upMC.play();
              _root.corneriaMC._y += movement;
              this.gotoAndStop(3);
              _root.playa.leftMC.play();
              _root.corneriaMC._x += movement;
              this.gotoAndStop(4);
              _root.playa.rightMC.play();
              _root.corneriaMC._x -= movement;
      any help appreciated!
        • 1. Re: hitTest trying to stop something moving
          you shouldn't attach code to objects.  but if you want to continue to use that, try:
          if(!hittestPositive){
              movement = 2.5;
                      movement = 0;
                      movement = 0;
                      movement = 0;
                      movement = 0;
          if(_root.playa.feetMC.hitTest( _root.corneria.limitsMC)){
          hittestPositive=true;
          • 2. Re: hitTest trying to stop something moving
            DOMIN8ER258 Level 1
            Maybe im not doing this right, the new code didnt work. Here is a much more detailed version.
            I have an MC called playa, in this MC I have another called feetMC.
            I also have an MC called corneriaMC, and in this I have an MC called limitsMC
            the feetMC is a rectangle, but the limitsMC is a completely irregular shape.
            I think my problem is the irregular limitsMC part of it.
            • 3. Re: hitTest trying to stop something moving
              hittest determines whether the bounding rectangles are colliding.  if you want to test against a non-rectangular shape you must use a shape-based hittest.  you can use gskinner's collisiondetection class.
