4 Replies Latest reply on Jun 15, 2010 9:14 AM by srinth
    how to convert xml to HierarchicalData dynamic
    srinth Level 1
      Hi All,
      How to convert the below xml data to HierarchicalData (arrayCollection) dynamic.
      <product model="Asus Eee PC T91" company="Asus" image="assets/Asus_Eee PC T91.png">
              <general>
                  <dimensions>10.3 * 6.5 * 1.05</dimensions>
                  <weight>2.6lb / 1.19kg</weight>
                  <startingPrice>$449</startingPrice>
                  <battery>3-cell Li-ion (std), 6-cell option</battery>
              </general>
          </product>
          <product model="Asus Eee PC T101H" company="Asus" image="assets/Asus_Eee PC T101H.png">
              <general>
              </general>
      </product>
      eg:
      private var dpHierarchy:ArrayCollection = new ArrayCollection([
              {FEATURE:"Genarel", children: [
                  {FEATURE:"Dimensions (in) w*d*h", obj1:"10.3 * 6.56 * 0.99", obj2:"10.3 * 6.5 * 1.05"},
                  {FEATURE:"Weight (lb/Kg)", obj1l:"2.13lb / 1.01kg" , obj2:"2.6lb / 1.19kg"},
                  {FEATURE:"Starting Price (US only)", obj1:"$399", obj2:"$449"},
                  {FEATURE:"Battery", obj1:"TBD, 3-cell 26 Whr (up to 3.5hrs), 6-cell 52 Whr (up to 7hrs)", obj2:"3-cell Li-ion (std), 6-cell option"},
      Thanks in advance
        • 1. Re: how to convert xml to HierarchicalData dynamic
          BhaskerChari Level 4
          Hi Srinath,
          You can make use of the SimpleXmlDecoder class in order to accomplish this task.
          Check the below code..It works perfectly for what you required...
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="loadData();" layout="absolute">
          <mx:Script>
            <![CDATA[
             import mx.collections.ArrayCollection;
             import mx.rpc.xml.SimpleXMLDecoder;
             private var loader:URLLoader = new URLLoader();
             [Bindable]public var dpHierarchy:ArrayCollection = new ArrayCollection();
             private function loadData():void
              var request:URLRequest = new URLRequest();
              request.url = "data.xml";
              loader.load(request);
              loader.addEventListener(Event.COMPLETE,dataLoadComp);
             private function dataLoadComp(event:Event):void
              var xml:XML = new XML(loader.data);
              var xmlDoc:XMLDocument = new XMLDocument(xml);
              var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
              var obj:Object = decoder.decodeXML(xmlDoc);
              dpHierarchy = obj.products.product as ArrayCollection;
          </mx:Script>
          </mx:Application>
          Note: You xml must contain only one root tag.
          So you xml should look....in data.xml file as below:
          <?xml version="1.0"?>
          <products>
              <general>
              </general>
          </product>
              <general>
              </general>
          </product>
          </products>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: how to convert xml to HierarchicalData dynamic
            srinth Level 1
            Hi Bhasker Chari,
            How to diplay this data in Advancedatagrid as grouded item. i tried with the code you share but unable to achive in grouped.
            eg:
            FEATUREProduct 1
            Product 2
            General
                dimensions copycopy
                weight  copycopy
                startingPrice     copycopy
                batterycopycopy
            Display
                screenSize  copycopy
                screenResolutioncopycopy
            Thanks ,
            Srinath
            • 3. Re: how to convert xml to HierarchicalData dynamic
              Hi Srinath,
              But your question was how to convert xml to HierarchicalData dynamic..right..
              For displaying data you can structure your data and add AdvancedDataGrid columns accordingly..
              Bhasker Chari
              • 4. Re: how to convert xml to HierarchicalData dynamic
                srinth Level 1
                Hi Bhasker Chari,
                Actually i need to display grouped view by using HierarchicalData format in advancedatagrid. using the below xml data:
                <notebook>
                <product model="Lenovo IdeaPad U150" company="Lenovo" image="assets/Lenovo IdeaPad U1501.png">
                          <general>
                               <dimensions>0.53” onwards thickness</dimensions>
                               <weight>2.97lb / 1.35kg</weight>
                               <startingPrice>699</startingPrice>
                          </general>
                          <display>
                               <screenSize>11.6” display</screenSize>
                               <screenResolution>1366 * 768</screenResolution>
                          </display>
                          <performance>
                               <storageSSD>64GB SSD</storageSSD>
                               <OS>Windows 7</OS>
                               <RAM>8GB DDR3 (max)</RAM>
                               <ODD>External SuperMulti DVD</ODD>
                          </performance>
                </product>
                <product model="Lenovo IdeaPad U1501" company="Lenovo" image="assets/Lenovo IdeaPad U1501.png">
                          <general>
                          </general>
                          <display>
                          </display>
                          <performance>
                               <OS>Windows 7</OS>
                          </performance>
                </product>
                </notebook>
                Srinath
