0 Replies Latest reply on Jun 14, 2010 4:56 AM by jfb00
    cfquery performance
    jfb00 Level 3
      Hi ALL
      I have to summary data from few tables base on different conditions. Here is a sample structure of my cf query:
      select id, C01, C02, C03, C04, C05, C06
            ,SUM(C07) as "C07"
            ,SUM(C08) as "C08"
            ,SUM(C09) as "C09"
            ,SUM(C10) as "C10"
            ,SUM(SU) as "SU"
            ,SUM(C12) as "C12"
            ,SUM(C13) as "C13"
          from (
           seleC12 mmr.id, mm.C01, mm.C02, mm.C03, mm.C04, mm.mission_module_type as C05, hC12.C06
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 2 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C07"
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 1 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C08"
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 3 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C09"
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 9 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C10"
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 4 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C11"
           ,CASE WHEN mmr.fy = #y# and mmr.si_id = 5 and mmt.total_mm_units > 0 then ((mmr.mm_rate / mmt.total_mm_units) * mmu.units) else 0  END as "C12"
           ,0 as "C13"
          from table01 mm, table02 mmr, table03 mmu,
          view2 mmt, table7 hC12
          where mm.id = mmr.id
          and mm.table01_id = mmu.table01_id
          and mmr.id = <cfqueryparam cfsqltype="cf_sql_integer" value="#arguments.id#">
          and mmr.fy = mmu.fy
          and mmt.id = mmr.id
          and mmt.fy = mmu.fy
          and mm.hull_class_tyC03 = hC12.hull_class_tyC03
          UNION ALL
           Another select statement
           case statements
           from table4
           join table5, join table6
          UNION ALL
           case  statements
           from table7
           join table8, join table9
        UNION ALL
           case  statements
           from table10
           join table11, join table12
         Group by id, C01, C02, C03, C04, C05, C06
         ORDER BY id, C02, C03, C01, C05, C06, C04
      I was reading this article:
      http://kb2.adobe.com/cps/170/tn_17081.html
      How can I improve the performance?
      Johnny
