3 Replies Latest reply on Jun 15, 2010 7:42 AM by jp77
    Urgent JSON container to as3 object.
    Antony52
      I have a JSON that comes as a container in the format {id:"", name:"", values:[]} etc. After using Json decode in what as3 type do I cast it and how do I access the various values? When I cast it to object I cannot seem to find out how to access the various fields. Thanks you.
        • 1. Re: Urgent JSON container to as3 object.
          jp77
          I have this JSON of string value pairs:
          var searchJSON:String = {"results":[{"name":"jack","surname":"four","avatar":"vpac://jack_Icon_.dat"},{"name":"je nny","surname":"three","avatar":"vpac://jenny_Icon_.dat"},{"name":"charles","surname":"two ","avatar":"vpac://charles_Icon_.dat"}]}
          To parse into an object or array whatever you prefer use this structure:
          var obj:Object = JSON.decode(searchJSON) as Object;
          trace(obj.results.length);
          Then depending on your object structure:
          for (var i:int; i<obj.results.length; i++)
               trace(obj.results[i].name);
               trace(obj.results[i].avatar);
          myList.dataProvider = new ArrayCollection(obj.results);
          etc ...
          I assume you have as3corelib.swc in your project libs folder, as this is where JSON.decode will be created from.
          Hope that helps!
          • 2. Re: Urgent JSON container to as3 object.
            Antony52 Level 1
            Thank you for the reply. I seem to get :"A term is undefined and has no properties" when in the line: var obj:Object =  JSON.decode(searchJSON) as Object; The json comes fine though?
            • 3. Re: Urgent JSON container to as3 object.
              jp77 Level 1
              Sorry made a mistake when cleaning out real project data in JSON String this is better: In full code this is how it looks:
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="doJSON()">
              <mx:Script>
              <![CDATA[
              import mx.collections.ArrayCollection;
              import com.adobe.serialization.json.JSON;
              private function doJSON():void
              var searchJSON:String = '{"results":[{"name":"jack","surname":"four","avatar":"vpac://jack_Icon_.dat"},{ "name":"jenny","surname":"three","avatar":"vpac://jenny_Icon_.dat"},{"name":"cha rles","surname":"two","avatar":"vpac://charles_Icon_.dat"}]}';
              myList.labelField =
              'avatar';
              </mx:Script>
              <mx:List id="myList" />
              </mx:Application>
