0 Replies Latest reply on Jun 14, 2010 7:28 AM by Sen Imagines
    Sending JSON format data with <mx:HTTPService> parameter
    Sen Imagines Level 1
      I wish to send a JSON structured data (string:
      {"data1":"ID001","data2":"myItemName","data3":"myItemParameter3","data4":"myItemParameter4 "})
      with <mx:HTTPService> using send(Parameter) to a Java function "myDataFunction.action"
      But when I send this kind of string, it is throwing error.
      I am creating an Object called: myParams
      To this, I add an attribute: param1
      param1 contains a JSON formatted string.
      I wish to pass this kind of string to the Java function.
      Can the Java function able to access this kind of string which is sent from Flex?
      Suggest me with the changes to be made so that I can achieve the above.
      -  Sen
      Below is the code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="0xFFFFFF" >
      <mx:HTTPService id="myHTTPServ" url="http://MyProjName/myDataFunction.action" resultFormat="e4x" showBusyCursor="true" fault="FaultHandler(event)" result="myResultHandler(event)" />
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      // START of Functions to get and handle chart Data for the specific ID
      public function callData():void
      var myitem1:String;
      var myitem2:String;
      var myitem3:String;
      var myitem4:String;
      var myitems:String;
      myitem1 = "ID001";
      myitem2 = "myItemName";
      myitem3 = "myItemParameter3";
      myitem4 = "myItemParameter4";
      var myParams:Object = new Object();// Create a parameter object for passing to the HTTPService
      //Data Structure to be sent as parameter:
      //{"data1":"ID001","data2":"myItemName","data3":"myItemParameter3","data4":"myItemParamete r4"}
      myitems = "{data1:"+myitem1+",data2:"+myitem2+",data3:"+myitem3+",data4:"+myitem4+"}";
      myParams.param1 = myitems;
      Alert.show(myParams.param1);
      callHTTPReq(myParams);
      public function callHTTPReq(myparams:Object):void
      myHTTPServ.send(myparams); // Call the HTTPService by passing the parameters
         private function myResultHandler(event:ResultEvent):void
      //Handling the received XML data
      // START of Common Fault Handler
              private function FaultHandler(event:FaultEvent):void
              Alert.show(event.fault.message);
      // END of Common Fault Handler
      </mx:Script>
      <mx:HBox width="100%">
      <mx:Button label="Home" click="callData()"/>
      </mx:HBox>
      </mx:Application>
