• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Popup (hyperlink) closes when using scroll bar
Guest
Jun 14, 2010 Jun 14, 2010
Robohelp (RH8).  The popup (hyperlink) closes when I use the scroll bar.  However, if I use the mouse wheel to scroll the popup does not close.  I am sure this is normal behavior however I would like it the stay open when using the scroll bar.  Is there a way to do this?
Views
549
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi pajamaham and welcome to the RH community.
To be honest I don't think you can do this with the method you are using. Popups were never designed to work that way. Perhaps a workaround would be to display the popup information in a new window. Not exactly elegant but it would do what you want.
  • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
  • Follow the RoboColum(n) on Twitter
Votes
Translate
Translate
Report
Report
Guest
Thank you, Colum.
I thought about doing that but I was hoping that someone may have a simple solution.  Thanks again!
Vic
Votes
Translate
Translate
Report
Report
Community Beginner ,
Jun 29, 2010 Jun 29, 2010
LATEST
On my system (RH8.0.2.208, Windows XP, HTML Help (CHM) output) I can scroll a popup with the vertical scrollbar but not with the mouse wheel. When I use KatMouse both scrollbars and mouse wheel work.
In the preview window (eyeglasses icon) both scrollbars and mouse wheel work.
The call I use is:
<a href="javascript:BSSCPopup('Welcome.htm');" id="a5">welcome</a>
which I make with Insert > Hyperlink, Display in auto-sizing popup.
--- Derek
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
