6 Replies Latest reply on Jun 16, 2010 11:19 AM by JeffLambert
    Can't make label change work in CS5
    JeffLambert Level 1
      Ok, so I've read the what's change in CS5 thread about the page items, but I can't figure out how to make it work. I've been out of the loop for a while so bare with me:-)
      Here's the script:
      --Changes the Slug Number and date on the active spread
      tell application "Adobe InDesign CS5"
      --this line is to make it work on the active layer only
      set myLayer to active layer of layout window 1 of document 1
      set myPage to active spread of layout window 1 of document 1
      try
      set mySlugframe_list to (all page items whose label is "MySlugFrame") -- was   -> text frame "mySlugFrame" of myPage
      repeat with j from 1 to count of mySlugframe_list
      set mySlugframe to item j of mySlugframe_list
      try
      set mynumber to (((text of cells "6:2" thru "6:2" of table 1 of mySlugframe) as string) as number)
      set mynumberText to (mynumber + 1) as string
      --remove the if statement if you need it to be on all layers
      if mySlugframe's item layer = myLayer then
      set text of cells "6:2" thru "6:2" of table 1 of mySlugframe to mynumberText
      set text of cell id 16 of table 1 of mySlugframe to "2010-06-10" --handler not shown to put the actual date here
      end if
      end try
      end repeat
      end try
      end tell
      The part that doesn't work is the set mySlugframe line. Item 1 of all page items whose label is "MySlugFrame" gets me something, but I want a list so I can change different things in it. Ideally, I would convert the cells I want to address with labels so it would be easier, but now just making this work would be good.
      TIA
      Jeff
        • 1. Re: Can't make label change work in CS5
          sstanleyau Level 4
          Try:
          every item of all page items whose label is "MySlugFrame"
          • 2. Re: Can't make label change work in CS5
            JeffLambert Level 1
            Hi Shane,
            It doesn't work, I get en error message saying, Can't get every item of all page items whose label = "MySlugFrame"
            I've tried to remove "all" from the code to see if it would work but to no avail.
            I found the doc and the example script ScriptLabel, though, I'll have a look at it and try to figure it out. In the mean time, if you have a solution for me, please feel free to help:-)
            Jeff
            • 3. Re: Can't make label change work in CS5
              SuperMacGuy Level 2
              Hi Jeff,
              does your script have a "tell document 1" statement? You need that (maybe you omitted it for brevity).
              • 4. Re: Can't make label change work in CS5
                JeffLambert Level 1
                Hi Chris,
                I'm still struggling with lists and how to use them properly. I've haven't touch scripting for a while and I'm just trying to migrate my CS4 script to CS5 but that change in page item structure messed up that script really bad. I found that I could do a if.. then statement like this...
                if label of page item i of myPage is "MySlugFrame" then
                but I can't get to my cell in my table after that. Conditional statements are another beast I have to master.
                The thing is, once I identify MySlugFrame, all there is in the frame is a table, then some cells, of which, 2 of them have also labels I could point to. I just have no clue of how to do it. What worked before doesn't anymore, or have just been lucky all along;-)
                Thanks.
                Jeff
                • 5. Re: Can't make label change work in CS5
                  sstanleyau Level 4
                  It was missing "of document 1".
                  • 6. Re: Can't make label change work in CS5
                    JeffLambert Level 1
                    ok, so I feel SOOOOO stupid right now... I was wondering where to put that "of document 1" and I finally found it. So for anybody interested, here's the script.
                    set theDay to make_two_digit(day of (current date))
                    set theMonth to make_two_digit(month of (current date) as number)
                    set theYear to year of (current date)
                    set theDate to theYear & "-" & theMonth & "-" & theDay as string
                    global theDate
                    tell document 1
                    --try
                    set mySlugframe_list to text frame 1 whose label is "MySlugFrame"
                    try
                    set text of cell id 16 of table 1 of mySlugframe to theDate
                    end if
                    end try
                    end repeat
                    --end try
                    end tell
                    end tell
                    on make_two_digit(the_number)
                    if the_number is less than 10 then
                    set the_result to "0" & the_number as string
                    else
                    set the_result to the_number as string
                    end if
                    end make_two_digit
                    I'm gonna try to make a call to the cell by label also, just to see if I can figure this one out:-)
                    THANKS!!!
                    Jeff
