0 Replies Latest reply on Jun 14, 2010 1:34 PM by SpiritOfTheWinds
    Need help to convert from AS3 to AS2
    SpiritOfTheWinds
      Okay, instead of my last post which I was looking for a AS2 slideshow sollution, I got this code in AS3 which would be easier to convert into AS2. I know it should work since I have the .fla in AS3. Thanks!
      ( I know that a big part will not change, but I would like you to change what should be changed. )
      import com.greensock.*;
      var imageLoader:Loader = new Loader();
      var imageLoader2:Loader = new Loader();
      var myTween:TweenLite;
      var myImages_array:Array = new Array;
      var myImages = ""; // Should be like "1.jpg|2.jpg|3.jpg|4.jpg" (from a  text file)
      var myDelay = 5;
      var img = 0;
      var ordre = 0;
      var image_total = 0;
      function init_slideshow()
           myImages_array = myImages.split("|");
           image_total = myImages_array.length;
           load_image(imageLoader,img);
           load_image(imageLoader2,img+1);
           img = img + 1;
           animate_slideshow();
      function animate_slideshow()
         if(ordre == 0)
             myTween = new TweenLite(myLoader, 2, {alpha:0,delay:myDelay,  onComplete:next_slide});
         else
             myTween = new TweenLite(myLoader2, 2, {alpha:0,delay:myDelay,  onComplete:next_slide});
      function next_slide()
           if(img >= image_total-1)
               img = -1;
           if(ordre == 0)
               setChildIndex(myLoader,0);
               setChildIndex(myLoader2,1);
               myLoader.alpha = 1;
               load_image(imageLoader,img+1);
               img = img + 1;
               ordre = 1;
           else
               setChildIndex(myLoader,1);
               setChildIndex(myLoader2,0);
               myLoader2.alpha = 1;
               img = img + 1;
               ordre = 0;
      function load_image(myMc,img)
           myMc.unload();
           if(ordre == 0)
               for(var i:uint = 0; i < myLoader.numChildren; i++){
                  myLoader.removeChildAt(i);
           else
               for(var z:uint = 0; z < myLoader2.numChildren; z++){
                     myLoader2.removeChildAt(z);
           myMc.load(new URLRequest("MyImagesURL/images/" +  myImages_array[img]));
      function hide_image()
           if(img == myImages_array.length - 1)
               img = 0;
           else
               img = img + 1;
           myTween = new TweenLite(myLoader, 5, {alpha:0,delay:myDelay,  onComplete:load_image, onCompleteParams:[img]});
      imageLoader.contentLoaderInfo.addEventListener(Event.COMPLETE,  function(e:Event){
         myLoader.addChild(e.target.content);
      imageLoader2.contentLoaderInfo.addEventListener(Event.COMPLETE,  function(e:Event){
         myLoader2.addChild(e.target.content);
      myLoader.x = 0;
      myLoader.y = 0;
      myLoader2.x = 0;
      myLoader2.y = 0;
      var url:String = "myURL";
      var loadit:URLLoader = new URLLoader();
      loadit.addEventListener(Event.COMPLETE, completeHandler);
      loadit.load(new URLRequest(url));
      function completeHandler(event:Event):void {
        myImages = event.target.data;
        init_slideshow();
      As for now, I have this (which is the last part  of the code above):
      rnd =  Math.floor(Math.random()*100000000);
      url = site_root + "/handler.ashx?id=" + _root.myid + "&rn="+rnd;  //Any existant image in the folder
      var sendLV:LoadVars=new LoadVars();
      var receiveLV:LoadVars=new LoadVars();
      receiveLV.onData=function(src){
          myImages = src;
           init_slideshow();
      sendLV.sendAndLoad(url,receiveLV,"POST");
