1 Reply Latest reply on Jun 15, 2010 1:28 AM by BhaskerChari
    Popupmanger.removePopup() is not removing instance
    Ankur Arora Level 1
      I have a application where I have a Login form which opens up in a popup using PopupManager.createPopup() method. I have a close button in the Login form which calls Popupmanager.removePopup(this); This login form also has an event listener which fired once login credentials are validated by the backend programming. Now if I close this popup using close button, reopen and try to validate login again the result event fires twice that means the earlier instance of Popup is still exist in the display list and its been just got hidden due to Popupmanager.removePopup() but I wanted to completely remove this from the display list. How can I do that.
      Any help is much appreciated.
      Ankur
      Flex & Flash experts
