3 Replies Latest reply on Jun 19, 2010 2:17 AM by T Beddard
    Setting input and output image sizes
    T Beddard Level 1
      I'm working on a new filter where I want to take a source image say 1024x512 pixels large, do some transformations and then want to render a resulting image at 512x512.
      Two questions:
      1) Is it possible to automatically set a float2 size parameter based on the input image size? e.g:
      input image4 src;
      parameter float2 size
        inputSize: float2(1024, 512);
        defaultValue: float2(1024, 512);
        displayName: "Input image size";
        componentName: "Width|Height";
        inputSizeName: "src";
      I would like the 'size' float2 to be automatically populated with the dimensions of input image 'src'. Note, if I don't specify the defaultValue parameter then the size always reverts to 0, 0.
      2) I have another parameter to set the outputSize and am currently doing it like this:
      parameter int2 outputSize
        minValue: int2(200, 200);
        maxValue: int2(4096, 4096);
        defaultValue: int2(1024, 512);
        stepInterval: 1;
        displayName: "Image size";
      region generated()
        return region(float4(0, 0, outputSize.x, outputSize.y));
      output pixel4 dst;
      However the actual rendered area is never less than the input image size, i.e. if I set the output image width to be 512 pixels it will always still render the same width as the input image 1024.
      I still haven't got my head round how regions should be used. How should I approach this?
      Thanks.
      Tom
      BTW, the filter I'm working on it for creating 'Little Planet' images (sterographic projection) from equirectangular panoramas. I'll be releasing it soon
