7 Replies Latest reply on Jun 22, 2010 4:14 PM by rtalton
    Horizontal Gap in MenuBar
    upshotvideo Level 1
      Hi
      I've looked high and low but can't figure out how to create custom space between the menuItems in a MenuBar. I'd think that horizontalGap would be a property but it's not.
      Thanks for any help.
        • 1. Re: Horizontal Gap in MenuBar
          rtalton Level 4
          Take a look at the menuStyleName property of the MenuBar. You can set padding properties here.
          You set these styles using CSS syntax, like "paddingBottom: 5;" and the menu bar will add 5 pixels under each menu item.
          • 2. Re: Horizontal Gap in MenuBar
            upshotvideo Level 1
            Sorry,
            I was a little to quick to mark this as answered.  This doesnt add padding to each menu item , but to the menuBar itself. I'm trying to add spacing between each menuItem in a horizontal menuBar.  paddingRight is not working for each item.
            • 3. Re: Horizontal Gap in MenuBar
              rtalton Level 4
              That's odd. can you post the relevant CSS code you are using?
              • 4. Re: Horizontal Gap in MenuBar
                upshotvideo Level 1
                I just whipped this up for an example.  It's similar to what I'm doing in my application.
                     <mx:Style>
                        .menuStyle{
                            paddingRight:20;
                    </mx:Style>
                    <mx:MenuBar id="myMenuBar" labelField="@label" menuStyleName="menuStyle">
                        <mx:XMLList>
                            <menuitem label="MenuItem A">
                                <menuitem label="SubMenuItem A-1" enabled="false"/>
                                <menuitem label="SubMenuItem A-2"/>
                            </menuitem>
                            <menuitem label="MenuItem B"/>
                            <menuitem label="MenuItem C"/>
                            <menuitem label="MenuItem D">
                                <menuitem label="SubMenuItem D-1"
                                          type="radio" groupName="one"/>
                                <menuitem label="SubMenuItem D-2"
                                          selected="true"/>
                                <menuitem label="SubMenuItem D-3"
                            </menuitem>
                        </mx:XMLList>
                    </mx:MenuBar>
                • 5. Re: Horizontal Gap in MenuBar
                  upshotvideo Level 1
                  Weird there is no way to accomplish this.  I still have not found a solution for the padding.
                  • 6. Re: Horizontal Gap in MenuBar
                    rtalton Level 4
                    Just had time to look at your code. It is working perfectly.
                    Just change "paddingRight" to "paddingBottom".
                    HTH
                    edit: Or are you trying to add space between the top-level menu bar items?
                    • 7. Re: Horizontal Gap in MenuBar
                      rtalton Level 4
                      If you are trying to add width to the top-level menubar items, you could do this.
                      <mx:Script>
                      <![CDATA[
                      import mx.controls.menuClasses.MenuBarItem;
                      private const MENU_ITEM_PADDING:Number = 25;
                      private function resizeMenuItems():void{
                      for each(var item:MenuBarItem in myMenuBar.menuBarItems){
                      item.width += MENU_ITEM_PADDING;
                      </mx:Script>
