7 Replies Latest reply on Jun 16, 2010 9:40 AM by thilgen
    Air 2.0 NativeProcess Communication Problem
    pseudohybriddesign
      Hello,
      I'm working on an AIR 2 application (a packager for air applications into *.exe). One of the options in the application is to check the validity of certificate's password. I'm using standardOutput method:
      private function checkCertPass():void{
                  file = new File();
                  file.nativePath = "C:/WINDOWS/system32/"
                  file = file.resolvePath("cmd.exe");
                  nativeProcessStartupInfo = new NativeProcessStartupInfo();
                  var processArgs:Vector.<String> = new
      Vector.<String>;
                  processArgs.push(javaPath.text);
                  processArgs.push("-jar");
                  processArgs.push(adtPath.text);
                  processArgs.push("-checkstore");
                  processArgs.push("-storetype");
                  processArgs.push("pkcs12");
                  processArgs.push("-keystore");
                  processArgs.push(certPath.text);
                  processArgs.push("-storepass");
                  processArgs.push(passField.text);
                  nativeProcessStartupInfo.arguments = processArgs;
                  nativeProcessStartupInfo.executable = file;
                  nativeProcess = new NativeProcess();
      nativeProcess.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA,
      onCertOutputData);
                  nativeProcess.start(nativeProcessStartupInfo);
              private function onCertOutputData(event:ProgressEvent):void{
                  var certResponse:String = new String();
                  certResponse =
      nativeProcess.standardOutput.readUTFBytes(nativeProcess.standardOutput.bytesAvailable);
                  trace(certResponse);
                  outputField.enabled = true;
                  outputField.text += certResponse;
                  if(certResponse.substr(0,5) == "valid"){
                      trace("Correct password!");
                      exeField.enabled = true;
      nativeProcess.removeEventListener(ProgressEvent.STANDARD_OUTPUT_DATA,
      onCertOutputData);
                      nativeProcess.exit();
                  }else{
                      trace("Incorrect password! Error...");
                      exeField.enabled = false;
      onCertOutputData);
      but I cannot establish communication i.e. all I receive after performing the code above is:
      Microsoft Windows XP [Version 5.1.2600]
      (C) Copyright 1985-2001 Microsoft Corp.
      C:\Program Files\Adobe\Flex Builder 3>
      What is wrong with this code? Why I can't receive the response?
      Thanks in advance,
      Nikola
        • 1. Re: Air 2.0 NativeProcess Communication Problem
          thilgen Level 4
          What happens if you add
            processArgs.push("/c");
          before
          Chris Thilgen
          AIR Engineering
          • 2. Re: Air 2.0 NativeProcess Communication Problem
            pseudohybriddesign Level 1
            Hi thilgen! First of all, thank you for your reply.
            I've tried your suggestion but in comparison to the preious output, now the output is totally blank (nothing is traced)...
            I really don't know where is the problem. Why I can't receive the answer "valid password" and subsequently to check it? If I write the code directly in the cmd console, everything is ok...
            • 3. Re: Air 2.0 NativeProcess Communication Problem
              thilgen Level 4
              Oops - I did not look at your original example close enough - please try this:
              file = new File(javaPath.text); // assume this is the path to java.exe...
              var processArgs:Vector.<String> = new Vector.<String>;
              nativeProcess.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onCertOutputData);
              Chris Thilgen
              AIR Engineering
              • 5. Re: Air 2.0 NativeProcess Communication Problem
                thilgen Level 4
                Okay Take 2:
                <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
                <mx:Script>
                  <![CDATA[
                  private var nativeProcess:NativeProcess;
                  private function onGo() : void {
                   outputField.text = "";
                   var file:File = new File("C:\\Program Files\\Java\\jdk1.6.0_20\\bin\\java.exe");
                   processArgs.push("C:\\Documents and Settings\\cthilgen\\Desktop\\sdk_0512\\lib\\adt.jar");
                   processArgs.push("C:\\Documents and Settings\\cthilgen\\Desktop\\cert-test\\test.p12"); // password is 'testpass'
                   var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
                   nativeProcess.addEventListener(ProgressEvent.STANDARD_ERROR_DATA,onCertOutputData);
                  private function onCertOutputData(event:ProgressEvent) : void {
                   certResponse = nativeProcess.standardError.readUTFBytes(nativeProcess.standardError.bytesAvailable);
                   if ( certResponse.substr(0,5) == "valid") {
                    nativeProcess.removeEventListener(ProgressEvent.STANDARD_ERROR_DATA,onCertOutputData);
                   } else {
                </mx:Script>
                <mx:Button label="go" click="onGo()" />
                <mx:TextInput id="passField"/>
                <mx:TextArea id="outputField" width="100%" height="100%"/>
                </mx:WindowedApplication>
                Please let me know if this gets you sorted.
                Chris Thilgen
                AIR Engineering
                • 6. Re: Air 2.0 NativeProcess Communication Problem
                  Hello thilgen. Problem is solved. Thank you once again for all your help.
                  Best regards,
                  Nikola
                  • 7. Re: Air 2.0 NativeProcess Communication Problem
                    thilgen Level 4
                    Excellent! Please let us know if you encounter any further issues.
                    Chris Thilgen
                    AIR Engineering
