18 Replies Latest reply on Jul 12, 2006 2:56 PM by Newsgroup_User
    pdfs, cfcs and webservices
    Level 7
      Hopefully someone can help me with this so I figure out what I'm doing
      wrong.
      I have a cfc that is using cffile to grab pdfs, avis, mpegs, etc. and
      returning it to the user. For some reason can't get it through to the user.
      On the "invoking page" I'm using cfheader and cfcontent to try and send the
      file as an attachment to the user, but it won't work. If I cfdump the
      variable I get data, but I'm never prompted to open/save the file. Using
      regular cfm pages I have no problems. I have tried read, readbinary,
      toBinary with no luck.
      Also I need this function to accessible as a webservice and trying that
      keeps returning an error about an invalid wsdl file and couldn't create
      stubs, but calling it from the same site results in the issue above but no
      wsdl error.
      CFC Code
      <cffunction name="getFile" access="remote" displayname="Get File" hint="I
      get a file based on the passed id.">
      <cfargument name="docID" type="string" required="yes">
      <cfset var doc = '' />
      <cfset var filePath = expandPath('../Web_Support_Doc/') & arguments.docID
      <cffile action="readbinary" file="#filePath#" variable="doc" />
      <cfreturn doc>
      </cffunction>
      Invocation Code
      <cfsilent>
      <cfset docFile =
      createObject('component','_cfcs.file').getFile('1255KITG.pdf') />
      </cfsilent>
      <cfheader name="Content-Disposition" value="attachment;
      filename=1255KITG.pdf">
      <cfcontent type="application/unknown" file="#docFile#">
      Web Service invocation code
      <cfset docFile =
      createObject('webservice',' http://innet/_cfcs/file.cfc?method=getFile&docID=#url.docID#')
      I'm using the same cfheader/cfcontent code from above to send to user.
      Any help would be greatly appreciated.
      Bryan Ashcraft (remove brain to reply)
      Web Application Developer
      Wright Medical Technologies, Inc.
      Macromedia Certified Dreamweaver Developer
      Adobe Community Expert (DW) :: http://www.adobe.com/communities/experts/
        • 1. Re: pdfs, cfcs and webservices
          Level 7
          No ideas? :(
          "Bash **AdobeCommunityExpert**" <bashcraft@wmtBRAIN.com> wrote in message
          news:e8n26h$fck$1@forums.macromedia.com...
          > wrong.
          > user. On the "invoking page" I'm using cfheader and cfcontent to try and
          > send the file as an attachment to the user, but it won't work. If I cfdump
          > the variable I get data, but I'm never prompted to open/save the file.
          > Using regular cfm pages I have no problems. I have tried read, readbinary,
          > wsdl error.
          > CFC Code
          > <cfreturn doc>
          > </cffunction>
          > Invocation Code
          > <cfsilent>
          > <cfset docFile =
          > </cfsilent>
          > <cfset docFile =
          • 2. Re: pdfs, cfcs and webservices
            Level 7
            What about putting the code to send the documents to the client in the
            cfc function. This is the only way I can even imagine this working as a
            webservice. Because, otherwise, what is the returntype for "document?"
            Bash **AdobeCommunityExpert** wrote:
            > No ideas? :(
            • 3. Re: pdfs, cfcs and webservices
              Level 7
              I'm obviously brain dead due to this deadline as I didn't even think of
              that. Thanks! I'll give it a shot.
              "Ian Skinner" <ian.skinner@bloodsource.org> wrote in message
              news:e8uk8h$ek2$1@forums.macromedia.com...
              > What about putting the code to send the documents to the client in the cfc
              >> No ideas? :(
              • 4. Re: pdfs, cfcs and webservices
                Level 7
                Well that didn't work either. :(
                >> No ideas? :(
                • 5. Re: pdfs, cfcs and webservices
                  Level 7
                  Can you provide some working, NON-CFC code. Serving up documents like
                  this is something I've only done once in the last ten years, and I do
                  not remember all the details.
                  • 6. Re: pdfs, cfcs and webservices
                    Level 7
                    If I use this code:
                    <!--- Send HTTP request for file from intranet and serve file to user--->
                    <cfhttp method="get" url=" http://domain/load_doc.cfm?doc=#url.doc#"
                    timeout="60" throwonerror="yes"></cfhttp>
                    </cfsilent>
                    <!--- Set default headers for serving file and serve file up to user--->
                    <cfheader name="Content-Type" value="pdf">
                    <cfheader name="Content-Disposition" value="attachment; filename=#url.doc#">
                    <cfcontent type="application/pdf">
                    <cfoutput>#cfhttp.filecontent#</cfoutput>
                    To call this code:
                    <!--- Define the full path to the docs --->
                    <cfset doc_path = expandPath("../../Web_Support_Doc/") & 'ACCSLIT.pdf' />
                    <!--- Verify the requested file exists --->
                    <cfif fileExists(doc_path)>
                    <!--- If file exists, serve it up --->
                    <cfcontent type="application/pdf" file="#doc_path#" />
                    <cfabort />
                    <!--- Otherwise display error --->
                    <cfelse>
                    <cfset error = "We're sorry, the file you have requested is not available."
                    <cfinclude template="error.cfm" />
                    <cfabort />
                    </cfif>
                    It works fine. But if I use this code:
                    <cfset docFile =
                    createObject('webservice',' http://innet/_cfcs/docLoader.cfc?method=read&docID=#url.docID#')
                    filename=#url.docID#">
                    <cfoutput>#docFile#</cfoutput>
                    <cfabort />
                    To call this code:
                    <cfcomponent>
                    <cffunction name="read" access="remote" displayname="Read File" hint="I
                    read a file based on the passed id." output="false" returntype="binary">
                    <cfif fileExists(filePath)>
                    <cffile variable="doc" action="readbinary" file="#filePath#" />
                    </cfif>
                    <cfreturn doc />
                    </cffunction>
                    </cfcomponent>
                    It doesn't.
                    news:e90s98$c07$1@forums.macromedia.com...
                    > this is something I've only done once in the last ten years, and I do not
                    • 7. Re: pdfs, cfcs and webservices
                      Level 7
                      I have been playing with this just a bit. I can make this work.
                      fileServing.cfm
                      <cfset testObj = createObject("component", "fileServing")>
                      <cfset testObj.serveFile("test.pdf")>
                      fileServing.cfc
                      <cfcomponent>
                      <cffunction name="serveFile" access="remote" returntype="void">
                      <cfargument name="fileToServe" required="yes" type="string">
                      filename=#arguments.fileToServe#">
                      <cfcontent file="G:\Playground\ProBono\#arguments.fileToServe#"
                      reset="no" type="application/unknown">
                      </cffunction>
                      </cfcomponent>
                      But when I try to use it as a web service, I get errors. I suspect that
                      a web service works differently and may not be easily usable in this
                      manner.
                      A clearer idea of what you goal is could be useful.
                      • 8. Re: pdfs, cfcs and webservices
                        Level 7
                        I have played with it some more and maybe getting closer. This gets a
                        file to download, but it is apparently corrupted and Adobe
                        Reader/Acrobat can not open it.
                        fileServing.cfm
                        <cfset myFile="test.pdf">
                        <cfheader name="Content-Disposition" value="attachment; filename=#Myfile#">
                        <cfset testObj = createObject("webservice",
                        " http://playground/probono/fileServing.cfc?wsdl")>
                        <cfcontent type="application/unknown">
                        <cfoutput>#binaryDecode(testObj.serveFile(myFile),"Hex")#</cfoutput>
                        fileServing.cfc
                        <cfcomponent>
                        <cffunction name="serveFile" access="remote" returntype="string">
                        <cfset var fileObj = "">
                        <cfset var returnVar = "">
                        file="g:\playground\probono\#arguments.fileToServe#" variable="fileObj">
                        <cfset returnVar = binaryEncode(fileObj,"Hex")>
                        <cfreturn returnVar>
                        </cffunction>
                        </cfcomponent>
                        • 9. Re: pdfs, cfcs and webservices
                          Level 7
                          Can you provide a sample of what #cfhttp.filecontent# is in this sample?
                          </cfsilent>
                          • 10. Re: pdfs, cfcs and webservices
                            Level 7
                            cfhttp.filecontent is simply the data returned from the cfhttp call. I can
                            post the big binary data dump if you want, but that is what the variable
                            contains.
                            The reason I'm doing this is because we have the files stored one server but
                            need them to be accessible from two separate servers. I wanted to use a web
                            service as it reduces the amount of code involved.
                            Thanks so much for all the effort you have put into this, I know I have been
                            banging my head against it for a while now.
                            news:e9164l$o5d$1@forums.macromedia.com...
                            > </cfsilent>
                            • 11. Re: pdfs, cfcs and webservices
                              Level 7
                              A small sample of the data dump would be fine, I was just curious if it
                              was an obvious encoding?
                              I am making a bit of progress, there is an error in the code, and the
                              error display is what is being downloaded to the reader.
                              > contains.
                              • 12. Re: pdfs, cfcs and webservices
                                Level 7
                                Well if one tries hard enough one can do most anything. The following
                                code is serving up PDF files from a web service! For some reason, I
                                could not get this to work by sending the data directly to the client
                                with the cfcontent tag, but by writing the data to a temp file and then
                                sending that file to the client with cfcontent worked.
                                Hopefully you can build on this to solve your problem.
                                fileServing.cfm
                                <cffile action="write" file="g:\playground\probono\tempServe.pdf"
                                output="#BinaryDecode(testObj.serveFile(myFile),'Base64')#"
                                addnewline="No" >
                                file="g:\playground\probono\tempServe.pdf" reset="no">
                                fileServing.cfc
                                <cfcomponent>
                                <cfset var file = "">
                                <cffile action="readBinary"
                                <cfset returnVar = binaryEncode(fileObj,"Base64")>
                                </cffunction>
                                </cfcomponent>
                                • 13. Re: pdfs, cfcs and webservices
                                  Level 7
                                  You rock!!!!
                                  Thank you so much. I'll just have to save it, serve it, delete it!
                                  news:e9196n$rj2$1@forums.macromedia.com...
                                  > code is serving up PDF files from a web service! For some reason, I could
                                  > not get this to work by sending the data directly to the client with the
                                  > cfcontent tag, but by writing the data to a temp file and then sending
                                  > fileServing.cfm
                                  > filename=#Myfile#">
                                  > addnewline="No" >
                                  > fileServing.cfc
                                  > <cfcomponent>
                                  > </cffunction>
                                  > </cfcomponent>
                                  • 14. Re: pdfs, cfcs and webservices
                                    Level 7
                                    I just thought of something of which you should be aware. I believe
                                    there is a potential for a race condition during your save it, serve it,
                                    delete it cycle.
                                    I suspect you will want to lock or otherwise control the access to this
                                    logic so that a second user is not saving a new file just before an
                                    earlier user is to be served and thus they both get the second user's file.
                                    > You rock!!!!
                                    • 15. Re: pdfs, cfcs and webservices
                                      Level 7
                                      Very good point. I was planning using the makeunique option of cffile to
                                      help with that. Adding a lock could further enhance this. Thanks!
                                      news:e91a6t$soo$1@forums.macromedia.com...
                                      >I just thought of something of which you should be aware. I believe there
                                      >is a potential for a race condition during your save it, serve it, delete
                                      >it cycle.
                                      > file.
                                      >> You rock!!!!
                                      • 16. Re: pdfs, cfcs and webservices
                                        Level 7
                                        Apparently these servers just don't like me. I get the binary data dumped on
                                        the page using your method.
                                        Basically I get a lot of this stuff:
                                        %PDF-1.2 %?? 12 0 obj << /Length 13 0 R /Filter /FlateDecode >> stream
                                        H?????????%=??6$Y`'??`gl??? ???\V????
                                        TF??=O??2#fS??(?X?o??1#???&k????z?@v
                                        ?'?8??5`qo!.?=??7???+????????Rf??
                                        ????h?????�f?w??L!????????2{WwU?? \??fkB???]???!????? iw??]???Cg? ??
                                        sf???;?P???0????~Ig3h??
                                        > fileServing.cfm
                                        > filename=#Myfile#">
                                        > addnewline="No" >
                                        > fileServing.cfc
                                        > <cfcomponent>
                                        > </cffunction>
                                        > </cfcomponent>
                                        • 17. Re: pdfs, cfcs and webservices
                                          Level 7
                                          Apparently this is an IE issue as it works fine FF.
                                          news:e93fdq$jfs$1@forums.macromedia.com...
                                          > on the page using your method.
                                          > ?? sf???;?P???0????~Ig3h??
                                          >> fileServing.cfm
                                          >> filename=#Myfile#">
                                          >> addnewline="No" >
                                          >> fileServing.cfc
                                          >> <cfcomponent>
                                          >> </cffunction>
                                          >> </cfcomponent>
                                          • 18. Re: pdfs, cfcs and webservices
                                            Level 7
                                            Nevermind had a Acrobat Reader install acting up for some reason. Reinstall
                                            seems to have fixed it.
                                            Thanks Again for all the help Ian!
                                            news:e93hh6$m1b$1@forums.macromedia.com...
                                            >>> fileServing.cfm
                                            >>> filename=#Myfile#">
                                            >>> addnewline="No" >
                                            >>> fileServing.cfc
                                            >>> <cfcomponent>
                                            >>> </cffunction>
                                            >>> </cfcomponent>
