4 Replies Latest reply on Jun 18, 2010 8:16 AM by 2425pike
    Timestamp Without Signature
    2425pike
      I have created a form using LiveCycle Designer with a button formatted to email me the completed form in PDF format. I would like to have the form timestamped upon submission but without requiring the other individual to sign it. Does anyone know if this is possible and if so, how it would be done?
        • 1. Re: Timestamp Without Signature
          Jasmin Charbonneau Level 4
          Can't you set a field with the current date and time before using JavaScript before your email the form?
          The problem with a submit button is that you can't add script to the click even. What you can do
          is have a regular button that has some JavaScript to set the field with the date and invoke your email button (ex. btnEmail.execEvent("click")). That way you can hide your email button and make the regular button act like it was the actual email button.
          I hope this make sense.
          Jasmin
          2 people found this helpful
          • 2. Re: Timestamp Without Signature
            2425pike Level 1
            Thanks, that does make sense. However, I unfortunately do not know enough about javascript to code the setting of the field. I have examined the code for the Date/Time field function, which is setting the time any new activity occurs on the form. However, I need it to simply set the time and not have it change. Perhaps you or someone can give me some direction on this. Here is the code for my email submit button and the code I had for the date/time field.
            <field name="Button1" y="222.25mm" x="85.725mm" w="31.75mm" h="12.7mm">
                        <ui>
                           <button highlight="inverted"/>
                        </ui>
                        <font typeface="Myriad Pro"/>
                        <caption>
                           <value>
                              <text>Submit by Email</text>
                           </value>
                           <para vAlign="middle" hAlign="center"/>
                        </caption>
                        <border hand="right">
                           <?templateDesigner StyleID apbx2?>
                           <edge stroke="raised"/>
                           <fill>
                              <color value="212,208,200"/>
                           </fill>
                        </border>
                        <bind match="none"/>
                        <event activity="click" name="event__click">
                           <submit format="pdf" target="mailto:myname@mycompany.com?subject=Code Completed Form " textEncoding="UTF-8"/>
                        </event>
                     </field>
            <field name="DateTimeField3" y="206.375mm" w="62mm" h="9mm" access="readOnly">
                        <ui>
                           <dateTimeEdit>
                              <border>
                                 <?templateDesigner StyleID aped3?>
                                 <edge stroke="lowered"/>
                              </border>
                              <margin/>
                           </dateTimeEdit>
                        </ui>
                        <margin topInset="1mm" bottomInset="1mm" leftInset="1mm" rightInset="1mm"/>
                        <para vAlign="middle"/>
                        <caption reserve="25mm">
                           <value>
                              <text>Timestamp</text>
                           </value>
                        </caption>
                        <calculate override="error"/>
                        <event activity="ready" ref="$layout" name="event__layout_ready">
                           <script>$.rawValue = Concat(Num2Date(Date(), "YYYY-MM-DD"), " ", Num2Time(Time(), "HH:MM:SS"))</script>
                        </event>
                        <?templateDesigner floatingFieldPlaceholder {current date/time}?></field>
            • 3. Re: Timestamp Without Signature
              How about you put this script on the click event of the button:
              if(TextField1.rawValue == null){
                  var now = new Date();
                  TextField1.rawValue  = now.toDateString() + now.toTimeString();
              btnEmail.execEvent("click");
              Jasmin
              • 4. Re: Timestamp Without Signature
                2425pike Level 1
                Thanks for pointing me in the right direction on this. What I ended up doing was adding javascript to my existing submit by email button. This is not the submit by email button but just a regular button where I changed the control type to submit. Under the first event tag, I added the following second event:
                event activity="mouseDown" name="event__mouseDown">
                script contentType="application/x-javascript">var rightNow = new Date();
                form1.subform1.TextField8.rawValue = (rightNow.toDateString()).substring(4,(rightNow.toDateString()).length) + " " + (rightNow.toTimeString()).substring(0,8);
                script>
                event>
                This filled in the text field I created with the current time from the pc as a static value, creating the timestamp I needed. Thanks again for your help!
