6 Replies Latest reply on Dec 6, 2010 3:58 AM by celebritymusic
    Having trouble saving .txt file from Flash
    celebritymusic Level 1
      Hi
      I successfully was able to save data from a Flash form to a txt file yesterday, but today NOT!  LOL - I have no idea what I've changed and done wrong, so was wondering if you guys could look?
      I'm using Jorge's code from Flash DB as the basics, but I can't ven get THAT to work now.
      Here's the as3 - I have made it so only one filed is required - "Title" - the as3 seems to be working fine:
      submit.addEventListener("mouseDown", sendData)
      function sendData(evt:Event){
          if(Title.text!=""){
              var myData:URLRequest = new URLRequest("save.php")
              myData.method = URLRequestMethod.POST
              var variables:URLVariables = new URLVariables()
              variables.Title = Title.text
              myData.data = variables
              var loader:URLLoader = new URLLoader()
              loader.dataFormat = URLLoaderDataFormat.VARIABLES
              loader.addEventListener(Event.COMPLETE, dataOnLoad)
              loader.load(myData)
          } else status_txt.text = "All fields are mandatory"
      function dataOnLoad(evt:Event){
          if(evt.target.data.writing=="Ok") {
             gotoAndStop(2)
         } else status_txt.text = "Error in saving submitted data"
      stop()
      And the php:
      <?php
         //Capture data from $_POST array
         $title = $_POST['Title'];
         //Make one big string in a format Flash understand
         $toSave = $title;
         //Open a file in write mode
         $fp = fopen("anastasio.txt", "w");
         if(fwrite($fp, $toSave)) echo "writing=Ok";
         else echo "writing=Error";
         fclose($fp);
      I've set the permissions on my ftp folder to 777
      But no txt file gets written.
      I'm wondering if yesterday's Flash update might affect this type of operation now?
      Thanks for taking alook.
      Shaun
        • 1. Re: Having trouble saving .txt file from Flash
          what's echo'd back?  do you have a file named anastasio.txt in the same directory with your php file, swf file and html file?
          • 2. Re: Having trouble saving .txt file from Flash
            Hey kglad
            Nothing is getting echoed back, and I've tried running it with and without that txt file in the folder.
            Here's my version of the php and as3 code - I just want the text that is in the text field 'everything' to be saved in (overwrite) the txt file 'settings' (I can set up checking for an empty text field) :
            <?php
               $everything = $_POST['saveThisData'];
               $toSave = $everything;
               $fp = fopen("settings.txt", "w");
               fclose($fp);
                    var myData:URLRequest = new URLRequest("save.php");
                    myData.method = URLRequestMethod.POST;
                    var variables:URLVariables = new URLVariables();
                    variables.saveThisData = everything.text;
                    myData.data = variables;
                    var loadData:URLLoader = new URLLoader();
                    loadData.dataFormat = URLLoaderDataFormat.VARIABLES;
                    loadData.addEventListener(Event.COMPLETE, dataLoadedBaby);
                    loadData.load(myData);
            function dataLoadedBaby(evt:Event){
                   saveSuccess.visible = true;
                   gotoAndPlay("machine");
               } else saveError.visible = true;
            Thanks for taking a look.
            Shaun
            • 3. Re: Having trouble saving .txt file from Flash
              jsanders1005
              i'm having the same problem. did you figure this out at some point?
              • 4. Re: Having trouble saving .txt file from Flash
                Hi jsanders
                I haven't loaded this project up for a while, but here is a cut n' paste of the code that was working:
                AS3:
                        var myData:URLRequest = new URLRequest("text_php_code.php");
                        var origEverything:String = "some test text";
                        variables.saveThisText = origEverything;
                    if(evt.target.data.writing.indexOf("Ok")>-1) {
                        savingXML.visible = false;
                        gotoAndPlay(4);
                   } else saveError.visible = true; savingXML.visible = false;
                PHP:
                <?php
                   //Capture data from Flash variable, and add it to "$everything"
                   $everything = $_POST['saveThisText'];
                   //stripslashes($everything);
                   $fp = fopen("test_text_file.txt", "w");
                   fclose($fp);
                Of course, it's tailored to my project, but it works and may just need a little tweaking to fit into your project.
                Hope it helps.
                Shaun
                • 5. Re: Having trouble saving .txt file from Flash
                  jsanders1005 Level 1
                  hey shaun,
                  thanks for the reply. i got it to work. i had a mistake because i was using some code from the db version on the same website...i wasn't reading carefully. thanks again.
                  best,
                  james
                  • 6. Re: Having trouble saving .txt file from Flash
                    You're welcome - glad it worked out.
