1. Re: interaction with listcontrol
Unni Gopinathan S Jun 17, 2010 2:24 AM (in response to Kristtee)Hi,
I have an sample xml file with content
<test>
<test1>
<id>h</id>
<content>Hello</content>
</test1>
<test1>
<id>w</id>
<content>World</content>
</test1>
</test>
In the design view of application add a List Control and TextArea.
List will display the text from the "id" elements in the XML and when user selects any id from the list corresponding text from the "content" element will be displayed in the textarea.
Create a new Data/Service ( Data/Services view in Flash Builder )using connect to data and assign that data to the list.
(Drag the corresponding API to the list and set the property "labelField" to the tag for binding)
Implement the change event handler which will get fired when a selection change happens in the list.
In the implementation get the selected item in list and get the corresponding element to be displayed in
the textarea and assign to the text property of the text area.
Following is the mxml for the sample application
<s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:test="services.test.*">
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.events.FlexEvent;
import spark.events.IndexChangeEvent;
[Bindable]
protected function list2_creationCompleteHandler(event:FlexEvent):void
getDataResult.token = test.getData();
protected function list2_changeHandler(event:IndexChangeEvent):void
contentDisplay.text = list2.selectedItem.content;
</fx:Script>
<fx:Declarations>
<s:CallResponder id="getDataResult"/>
<test:Test id="test" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<mx:Form >
<s:List x="76" y="34" width="112" height="168" id="list2" creationComplete="list2_creationCompleteHandler(event)"
labelField="id" change="list2_changeHandler(event)">
<s:AsyncListView list="{getDataResult.lastResult}"/>
</s:List>
<s:TextArea x="73" y="222" id="contentDisplay"/>
</mx:Form>
</s:WindowedApplication>Screen Shot:
Please let me know if this sample helps to solve your problem.
Unni
