2 Replies Latest reply on Jun 16, 2010 11:16 PM by ilsh
    update application error (from 1.5 to 2)
    ilsh Level 1
      today I download AIR 2.02 SDK and recompile my app. The only thing I changed is the first line of the descriptor file:
      <application xmlns="http://ns.adobe.com/air/application/2.0"> (changed from 1.5 to 2.0)
      I did not change the id field.
      After I package the app, and double click to install it, an error occurs:
      "The application could not be installed because an application with that name already exists at the selected installation location. Try installing to a different location."
      I have to uninstall the app (packaged using 1.5 SDK) first. Is this supposed to be the case?
        • 1. Re: update application error (from 1.5 to 2)
          neh@adobe Level 3
          An app is identified by its appid + publisherID. For namespace 1.5, publisherid is created by default. However, for apps with version 2.0, publisherid field is used to upgrade existing applications(created with namespace <=1.5).
          The only thing you need to do is to locate the publisherid of your installed app ( you can find it from your installed app folder:
          On Linux, it is: <app install folder: by default it is: /opt/<appname>>/share/META-INF/AIR/publisherid
          On Win XP, it is:<app install folder: by default it is: c:\program files\<appname>>\META-INF\AIR\publisherid
          Just copy the contents of this publisherid file into the <publisherID> tag in the app.xml(with 2.0 namespace):
          <publisherID></publisherID>
          Hope this solves your problem.
          • 2. Re: update application error (from 1.5 to 2)
            ilsh Level 1
            Thank you. It explains.
