8 Replies Latest reply on Jun 16, 2010 4:45 AM by Ibarim
    arrayCollection modification changes other arrayCollections
    Ibarim Level 1
      I need to create an arrayCollection as a copy of other arrayCollection. Then I need to change some data inside the copy, but when I do that the original arrayCollection changes as well. Is there a way to stop the changes in the original arrayCollection?
      For example I got: arrColOrig[0].someVar = 1
      I've tried:
      arrColCopy = new arrayCollection (arrColOrig.source)
      arrColCopy[0].someVar = 2
      effect is that arrColOrig[0].someVar = 2
      I've tried also:
      arr = new Array
      arr = arrColOrig.source
      arrColCopy = new arrayCollecion (arr);
      effect is that 'someVar' changes to value '2' in arr and in arrColCopy and in arrColOrig
      So is there a way to maintain the original arrayCollection unchanged? I know that I can create the copy by looping the original  arrayCollection, but I'm looking for a simpler way.
        • 1. Re: arrayCollection modification changes other arrayCollections
          David_F57 Level 5
          hi,
          You always have to be careful when copying objects as most of the time all you are really doing is creating a pointer which can become a disaster, Objectutil is the safest way to make copies.
          import mx.utils.ObjectUtil;
          var myCollection: ArrayCollection = ObjectUtil.copy(originalArrayCollection);
          David
          • 2. Re: arrayCollection modification changes other arrayCollections
            Ibarim Level 1
            Thanks for help,
            I've tried your solution but there is one problem, I get error:
            Implicit coercion of a value with static type Object to a possibly unrelated type mx.collections:ArrayCollection
            Have you met this error when using ObjectUtil?
            • 3. Re: arrayCollection modification changes other arrayCollections
              David_F57 Level 5
              hi,
              thats what happens when you do things of the top of your head,  i forgot the important bit.....
              arr2 = ObjectUtil.copy(arr1) as ArrayCollection;
              David
              • 4. Re: arrayCollection modification changes other arrayCollections
                Ibarim Level 1
                Thanks, works like a charm:)
                As my arrayCollection is filled with object I was getting to use loop:
                for (i=0;i<arr1.length;i++) {
                       arr2.addItem(ObjectUtil.copy(arr1[i]));
                and it worked, but coping whole array at once is much more simple.
                • 5. Re: arrayCollection modification changes other arrayCollections
                  BhaskerChari Level 4
                  Hi lbarim,
                  We can also use the below code to copy the array collection:
                  var copyArrayCol : ArrayCollection = new ArrayCollection(orgArrayCol.toArray());
                  Bhasker Chari
                  • 6. Re: arrayCollection modification changes other arrayCollections
                    Ibarim Level 1
                    Hi BhaskerChari,
                    I was trying your solution, but the effect is the same: original array changes when you modify it's copy.
                    I was trying also various combinations of arrCol.source and arrCol.source.slice(), but none of it worked. It was strange, becouse 'slice()' method should create a copy (it's said in adobe livedocs).
                    So I'll stick to David_F57 solution with 'ObjectUtil.copy()'.
                    • 7. Re: arrayCollection modification changes other arrayCollections
                      Hi lbarim,
                      Check the below application and also observe my comments:
                      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
                      <mx:Script>
                        <![CDATA[
                        import mx.collections.ArrayCollection;
                        private var orgArrayCol:ArrayCollection =  new ArrayCollection([{label:"ALL",data:null},
                                  {label:"OTHER",data:"OTHER"},
                                  {label:"SOME",data:"PARTIAL"}]);
                        private function copyArrayCollection():void
                         // No chnage on original ArrayCollection performing these two operations
                         copyArrayCol.removeItemAt(0);
                         copyArrayCol.addItemAt(orgArrayCol.getItemAt(0),0);
                         // You should not use this approach for changing a property at particular index
                         // You need to use below appraoch
                         // If you use this approach it will change the label property in both the ArrayCollection
                         copyArrayCol.getItemAt(0).label = "SOME ALL";
                         // You need to follow this appraoch to change any property(say label) at any particular index
                         // This will chnage the label property only in copyArrayCol ArrayCollection
                         var obj:Object = copyArrayCol.getItemAt(0);
                         obj.label = "SOME ALL";
                         copyArrayCol.setItemAt(obj,0);
                      </mx:Script>
                      </mx:Application>
                      Bhasker Chari
                      • 8. Re: arrayCollection modification changes other arrayCollections
                        Ibarim Level 1
                        In my case I needed to change the property at particular index - that's why
                        code:
                        'copyArrayCol[0].label = "new label" '
                        didn't work for me when I used:
                        'var copyArrayCol : ArrayCollection = new
                        ArrayCollection(orgArrayCol.toArray());'.
                        I don't have time to check your other solution, when I got one working
                        already (ObjectUtil.copy), so I have to trust you that it works as well
                        Thanks for your time
