5 Replies Latest reply on Jun 17, 2010 4:09 PM by Flex harUI
    Text on Sprite problem
    Ianvn.za Level 1
      I am trying to add text to a center of a sprite object.
      Here is a example picture of the result I'm getting.
      The code I'm using is the following.
                          var spr:Sprite = new Sprite();
                          var txt:TextField = new TextField();
                          txt.text = "text";
                          txt.textColor = 0x000000;
                          spr.graphics.beginFill(0x78910E);
                          spr.graphics.drawCircle(50,50, 20);
                          spr.graphics.endFill();
                          spr.addChild(txt);
                          uiComp.addChild(spr);
      Where uiComp is a mx:UIComponent.
      Any help would be appreciated.
        • 1. Re: Text on Sprite problem
          Flex harUI Adobe Employee
          Gotta set the x,y on txt.
          • 2. Re: Text on Sprite problem
            Ianvn.za Level 1
            Thanks for the previous reply.
            That worked perfectly.
            I made a change to my code to start drawing at 0,0 and afterwards moving the sprite to my desired x and y coordinates.
            var rect:Rectangle = new Rectangle();
            txt.text = "text";
            spr.graphics.lineTo(239,3);
            spr.graphics.lineTo(213,37);
            spr.graphics.lineTo(187,3);
            spr.addChild(txt);
            spr.x = 50;
            spr.y = 50;
            rect = spr.getRect(uiComp);
            var nVal:Number;
            var nVal2:Number;
            nVal = Math.abs(rect.topLeft.x) + ((Math.abs(rect.bottomRight.x) - Math.abs(rect.topLeft.x)) / 2);
            nVal2 = Math.abs(rect.topLeft.y) + ((Math.abs(rect.bottomRight.y) - Math.abs(rect.topLeft.y)) / 2);
            txt.x = nVal;
            txt.y = nVal2;
            Using this method I get the following result:
            For some reason the x and y coordinates it returns are outside the bounds of the sprite.
            nVal and nVal2 are supposed to be the centre point of the sprite.
            Any ideas why this would be happening?
            • 3. Re: Text on Sprite problem
              I suspect you are not calculating relative to the right object.  I don't
              think you should need the topLeft to calculate center if the rect is based
              on the parent.
              • 4. Re: Text on Sprite problem
                Ianvn.za Level 1
                What I don't really understand is the results I'm getting from the getRect function.
                It getRect returns my topleft as 50,50 which is fine, because thats where I set the sprite, but it returns the bottomright coordinates as 289,150. The x value I can almost understand but the y value looks way off if you look at the coordinates I used to draw the sprite.
                Am I using the correct way to get the coordinates or are there a better way of calculating the center point of the sprite?
                • 5. Re: Text on Sprite problem
                  Just get the .width and .height properties
