7 Replies Latest reply on Jul 22, 2010 10:02 AM by heyitsjuan
    AIR 1.5.2 vs AIR 2.0 outer left join - column name issues
    JMSTrilsoft
      Hi All,
      I was wondering if anyone has seen this or know a workaround to this issue.
      After a machine got updated to AIR 2.0 our apps started to fail. Upon further inspection I discovered that the column names in the return results from an SQLite query using "outer left join" were different between AIR 1.5.2 and AIR 2.0.
      Here's my proof of concept: (I attempted to make this as sort as possible but reproduce the issue)
      private function runTest():void{
                          var conn:SQLConnection = new SQLConnection();
                          var stmt:SQLStatement = new SQLStatement();
                          var res:Array = [];
                          stmt.text = "SELECT tableOne.int, tableAlias.varchar " +
                                    "from tableOne " +
                                    "outer left join (SELECT * FROM tableTwo) as tableAlias " +
                                    "on (tableOne.int == tableAlias.int)";
                          conn.open(File.applicationDirectory.resolvePath("tempdb.db"));
                          stmt.sqlConnection = conn;
                          stmt.execute();
                          conn.close();
                          res = stmt.getResult().data as Array
                          trace(ObjectUtil.toString(res));
      AIR 1.5.2 trace results:
      (Array)#0
        [0] (Object)#1
          tableAlias_varchar = "apple"
          tableOne_int = 0
        [1] (Object)#2
          tableAlias_varchar = "boat"
          tableOne_int = 1
        [2] (Object)#3
          tableAlias_varchar = "cat"
          tableOne_int = 2
      AIR 2.0 trace results:
      (Array)#0
        [0] (Object)#1
          int = 0
          varchar = "apple"
        [1] (Object)#2
          int = 1
          varchar = "boat"
        [2] (Object)#3
          int = 2
          varchar = "cat"
