7 Replies Latest reply on Jun 17, 2010 10:55 PM by kglad
    [AS2] Send MovieClip colour value to dynamic text box
    TP Artroom
      I've been struggling to figure this bit out and it's driving me crazy.
      What happens in my flash file is I click on a colour swatch and that colour is then stored until I click on the part of the shirt I want to change colour. Once that part of the jersey has changed colour I want to be able to send the colour from just that section to a dynamic text field (to be emailed later as a reference). As an example, I click on "btn_orange" and then click on the Movie Clip "block1". "block1" changes to orange. As it changes I want to send "block1"'s colour to a text box called "hexcode1". If "block1" colour changes, then so will the text box "hexcode1". "block2" will be linked to "hexcode2" etc.
      Hopefully this explains it better. I would really appreciate any help as this is the major thing holding me back from completing this.
      Thanks for checking this out.
      Frame Script:
      var storedColor:String;
      color_txt.html = true;
      color_txt.autoSize = true;
      color_txt.htmlText = "Choose a color swatch";
      function setSwatchColor(colorNum:String):Void {
          storedColor = colorNum;
          var swatch:Color = new Color(swatch_mc);
          swatch.setRGB(parseInt(colorNum));
          color_txt.htmlText = colorNum;
      function changeColor():Void {
          var col:Color = new Color(this);
          col.setRGB(parseInt(storedColor));
      btn_maroon.onPress = function() {
          setSwatchColor("0x660033");
      btn_red.onPress = function() {
          setSwatchColor("0xFF0000");
      btn_orange.onPress = function() {
          setSwatchColor("0xFF6600");
      block1.onPress = changeColor;
      block2.onPress = changeColor;
      IMAGE OF FLASH IN OPERATION
      Messy while I'm debugging.
      http://i50.tinypic.com/ir23km.jpg
        • 1. Re: [AS2] Send MovieClip colour value to dynamic text box
          use:
          var tl:MovieClip=this;
          tl["hexcode"+this._name.substring(4)].text=storedColor;
          • 2. Re: [AS2] Send MovieClip colour value to dynamic text box
            TP Artroom Level 1
            KGLAD:
            I tried your code, but couldn't get any joy from it. I've uploaded the source so you or anyone else can have a look and see why it may be occuring. Please be aware I still have cleaning to do on this and I've left the Email Movie Clip box up so hexcode & hexcode1 can be viewed. Thankyou for looking and hopefully there's a solution. Here's the source.
            http://www.tripleplay.com.au/tmp/flash.fla
            The code is on the layer "Action Script Layer" and the start frame for 1st design script is Frame 13. hexcode & hexcode1 are inside the email_box MovieClip up the top. block1 & block2 are apart of the design. "hexcode" instance name is hex_num1 and "hexcode1" instance name is hex_num2 so I'm looking at sending block1 colour to hex_num1 instance and block2 colour to hex_num2 instance.
            Thanks for looking.
            • 3. Re: [AS2] Send MovieClip colour value to dynamic text box
              what's the following trace() show:
              trace(color_txt+" "+colorNum);
              • 4. Re: [AS2] Send MovieClip colour value to dynamic text box
                TP Artroom Level 1
                This is the output of the trace.
                _level0.color_txt 0x660033
                • 5. Re: [AS2] Send MovieClip colour value to dynamic text box
                  oops, wrong textfield.  (and that string method needs an adjustment).  use:
                  tl["hexcode"+this._name.substring(5)].text=storedColor;
                  trace("hexcode"+this._name.substring(5)+" "+tl["hexcode"+this._name.substring(5)]);
                  • 6. Re: [AS2] Send MovieClip colour value to dynamic text box
                    TP Artroom Level 1
                    Thankyou very much. After a little bit of tinkering I found my problem was that the dynamic text fields were inside a movie clip and that was causing some problems. Appreciate you help very much. Thankyou again.
