0 Replies Latest reply on Jun 17, 2010 1:57 AM by envirographics
    Partial delete of copy of graphic on new layer sees source graphic vanish !
    envirographics Level 1
      Deleting part of the graphic on an upper layer sees same artwork disappear on a lower layer.
      Here is the procedure.
      Artwork (properties..graphic) of a map border and symbols exists on a flash layer.
      Select layer and go edit duplicate. Makes a stepped away copy.
      Edit cut and make new layer over this one and go edit>paste, and make it also x0 y0. Now they superimpose.
      Turn off vis on lower one and d/click the art still showing, drag select the symbols and delete. Leaves just map border. Return to scene_1.
      Turn off vis for this and turn on the lower layer, and its artwork has also vanished !!!!!!!!!!!!!
      Even tried selecting the first layers artwork, going edit copy, then make a layer above, ed paste, then delete the symbols leaving border, and still the art on the lower layer is zapped.
      Why ?
      How can I clone this artwork and remove the symbols from the one, and the border from the other ?
      Envirographics
