4 Replies Latest reply on Jun 17, 2010 7:04 AM by xpsdeset
    UserService response to array
    xpsdeset
      I am very new to flex.
      Now
      getChatsResult.token = usersService.getChats();
      The line generates token I want is that the result generated by the service
      i want to format the result in an array of objects an example would be helpfull.
      i mean
      var chats:Array = usersService.getChats();
      for(i=0;i<chats.length;i++)
      text.Text+=chat[i]["chat"]+"\n";
      But the above is not working.
        • 1. Re: UserService response to array
          BhaskerChari Level 4
          You need to add the responder for the asyncToken...that means that you need to register response and fault handlers on asyncToken object.See the below code:
          var asyncToken:AsyncToken = usersService.getChats();
             asyncToken.addResponder(new mx.rpc.Responder(
              function result(result:ResultEvent):void
                  var chats:Array = result.result; // try to analyse here the result variable and manipulate the code here accordingly..
              function fault(event:FaultEvent):void
               Alert.show(event.fault.faultString);
          Note: It's always a good practice to register eventHandlers for an asynchronous operation.
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: UserService response to array
            xpsdeset Level 1
            Thanks a lot Bhasker Chari for your reply.
            Sorry I am a newbie at flex.
            Below is my code its givingfollowing errors
            Type was not found or was not a compile-time constant: AsyncToken.
            Type was not found or was not a compile-time constant: FaultEvent.
            Type was not found or was not a compile-time constant: ResultEvent.
            <s:CallResponder id="getChatsResult"/>
            I even imported
                        flash.events.Event
            protected function ChatSend_keyDownHandler(event:KeyboardEvent):void
                                //var asyncToken:AsyncToken = usersService.getChats();
                                getChatsResult.addResponder(new mx.rpc.Responder(
                  }//end of function
            • 3. Re: UserService response to array
              You need to import the namespaces in your page.
              import mx.rpc.AsyncToken;
              import mx.rpc.Responder;
              import mx.rpc.events.FaultEvent;
              import mx.rpc.events.ResultEvent;
              It seems that you are using the Flex4...any way try to import these namespaces if this namespaces are not recognised try to use the namespaces relevant in Flex4.
              Bhasker Chari
              • 4. Re: UserService response to array
                xpsdeset Level 1
                Thanks a Lot Bhasker Chari you  made my day.
