1 Reply Latest reply on Jun 17, 2010 5:55 AM by ComboDrums
    Execute .bat file with AIR 2.
    ComboDrums Level 1
      Hi!
      I'm trying to execute a .bat file with AIR 2 to do some SVN function with subversion installed on my Windows XP machine. I know it's impossible directly so I use cmd.exe and i pass params to the .bat but the only trace I have is :
      Microsoft Windows XP [version 5.1.2600]
      (C) Copyright 1985-2001 Microsoft Corp.
      C:\Program Files\Adobe\Adobe Flash Builder 4>
      Here is my very simple .bat file :
      svn.exe checkout --username "%1" --password "%2" "%3" "%4"
      And here is my MXML code :
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                  xmlns:mx="library://ns.adobe.com/flex/mx"
                                  applicationComplete="windowedapplication1_applicationCompleteHandler(event)"
           <fx:Declarations>
                <!-- Placer ici les éléments non visuels (services et objets de valeur, par exemple). -->
           </fx:Declarations>
           <fx:Script>
                <![CDATA[
                     import flash.desktop.NativeProcess;
                     import mx.events.FlexEvent;
                     private var process:NativeProcess;
                     protected function windowedapplication1_applicationCompleteHandler(event:FlexEvent):void
                          var cmd:File = new File("C:\\WINDOWS\\system32\\cmd.exe");
                          var svn:File = new File(File.applicationDirectory.nativePath + File.separator + "svn.bat");
                          var args:Vector.<String> = new Vector.<String>();                    args[0] = "toto";
                          args[0] = svn.nativePath;
                          args[1] = "my_login";
                          args[2] = "my_pass";
                          args[3] = "svn_url";
                          args[4] = "E:\\workspace\\test_svn";
                          var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
                          nativeProcessStartupInfo.executable = cmd;
                          nativeProcessStartupInfo.arguments = args;
                          process = new NativeProcess();
                          process.addEventListener(NativeProcessExitEvent.EXIT, onExit);
                          process.addEventListener(Event.STANDARD_ERROR_CLOSE, standardErrorClose);
                          process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, onErrorData);
                          process.addEventListener(IOErrorEvent.STANDARD_ERROR_IO_ERROR, onIOError);
                          process.addEventListener(Event.STANDARD_INPUT_CLOSE, standardInputClose);
                          process.addEventListener(IOErrorEvent.STANDARD_INPUT_IO_ERROR, onIOError);
                          process.addEventListener(ProgressEvent.STANDARD_INPUT_PROGRESS, standardInputProgress);
                          process.addEventListener(Event.STANDARD_OUTPUT_CLOSE, standardOutpoutClose);
                          process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onOutputData);
                          process.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, onIOError);
                          process.start(nativeProcessStartupInfo);
                     public function standardOutpoutClose(evt:Event):void
                          trace("standardOutpoutClose");
                     public function standardInputProgress(evt:ProgressEvent):void
                          trace("standardInputProgress");
                     public function standardInputClose(event:Event):void
                          trace("standardInputClose");
                     public function standardErrorClose(event:Event):void
                          trace("standardErrorClose");
                     public function onOutputData(event:ProgressEvent):void
                          trace("Got: ", process.standardOutput.readUTFBytes(process.standardOutput.bytesAvailable));
                     public function onErrorData(event:ProgressEvent):void
                          trace("ERROR -", process.standardError.readUTFBytes(process.standardError.bytesAvailable));
                     public function onExit(event:NativeProcessExitEvent):void
                          trace("Process exited with ", event.exitCode);
                     public function onIOError(event:IOErrorEvent):void
                          trace(event.toString());
           </fx:Script>
      </s:WindowedApplication>
      What is wrong with this code?
      Thx for your help.
        • 1. Re: Execute .bat file with AIR 2.
          ComboDrums Level 1
          I found the solution! Thanks to my network admin.
          I have to put "/c" in the first argument to tell cmd.exe I want to execute a command :
          args.push("/c", svn.nativePath, "my_login", "my_pass", "svn_url", "E:workspace" + "\\" + "test_svn");
