3 Replies Latest reply on Jul 15, 2010 11:05 PM by abazizis
    Is there a "addPhotosToPublishedCollection"?
    L. Hagen Level 1
      is there any function (callback) that is triggered when a photo is being assigned (e.g. via drag&drop) to a publishedCollection?
      thanks and regards,
      Lars
        • 1. Re: Is there a "addPhotosToPublishedCollection"?
          Allen Gambrell Level 1
          I have not seen what you are looking for.
          I can think of alot of reasons for it mainly preventing the user from adding images to s certain published collection, only let the plugin add and remove them.
          • 2. Re: Is there a "addPhotosToPublishedCollection"?
            L. Hagen Level 1
            Let me try to explain a bit differently: I move any photos to a published collection (e.g. via drag&drop). Usually, the photo(s) will now be published the next time you will press "publish" button.
            But it would be useful to get any kind of notification or better a callback to trigger a custom user function. In my case such a user function could make some tests on the server to decide whether the picture shall really be published or not (before the user is pressing the "publish" button).
            A better example for such a callback is to handle "image moves". Currently, it is possible to drag&drop an image from a published collection to another published collection. The effect is that this photo will be "copied" and is then twice available in the publish service. That is a terrible behavior, because you cannot handle and/or prevent this! A mentioned callback would allow to check whether the photo is already available and allow to make some processing.
            • 3. Re: Is there a "addPhotosToPublishedCollection"?
              abazizis
              What you can do is postpone the check until exportServiceProvider.processRenderedPhotos is called. Do your check here doit prior to    for i, rendition in exportContext:renditions { stopIfCanceled = true } do statement. If you don't want to process it set it to skipRender()..
