9 Replies Latest reply on Jun 18, 2010 4:37 AM by PankChat
    Select previous page items or next page items (IDCS3)
    PankChat Level 1
      Hello all,
      How can I refer to previous page or its item? I am trying to do something below. if a textFrame with label "myFrame" is missing on current page go to next page (or may try to next page)
      for (var i=0; i<=myTotalPage-1; i++)
      app.activeWindow.activePage =myDoc.pages[i];
      //$.writeln ("Page is :"+myDoc.pages[i].name);
      if(!(myDoc.pages[i].textFrames.itemByName("sections")!=null))
      var myText="sometext";
      myDoc.pages[i].previousItem ().textFrames.itemByName("myFrame").insertionPoints.item(-1).properties = { appliedCharacterStyle : "myCharacterStyle", contents:myText};
      else{
      var myText="anotherText";
      myDoc.pages[i].textFrames.itemByName("myFrame").insertionPoints.item(0).properties = { appliedCharacterStyle : "myCharacterStyle", contents:myText};
      I know that previousItem () is not supported here, just added it to make the things clear.
      Any suggestions greatly appreciated.
      TIA,
      --PC
        • 1. Re: Select previous page items or next page items (IDCS3)
          Kasyan Servetsky Level 5
          Try to reference next/previous page like so:
          var myPage = myDoc.pages[i];
          var myPreviousPage = myDoc.pages.previousItem(myPage);
          var myNextPage = myDoc.pages.nextItem(myPage);
          Kasyan
          • 2. Re: Select previous page items or next page items (IDCS3)
            Harbs. Level 6
            Or you can just use the documentOffset:
            prevPage = doc.pages.item(page.documentOffset+1);
            nextPage = doc.pages.item(page.documentOffset+1);
            fivePagesLater = doc.pages.item(page.documentOffset+5);
            Harbs
            • 3. Re: Select previous page items or next page items (IDCS3)
              Larry G. Schneider Adobe Community Professional & MVP
              Harbs,
              Did you possibly mean -1 for previous page?
              • 5. Re: Select previous page items or next page items (IDCS3)
                PankChat Level 1
                Thanks Kasyan, Harbs. I shall give a try and revert.
                --PC
                • 6. Re: Select previous page items or next page items (IDCS3)
                  PankChat Level 1
                  Well I tried using Kasyan's suggestion but it outputs me error (object is
                  not valid). I thought var myPreviousPage =
                  myDoc.pages.previousItem(myPage); will suffice to pass the reference for
                  the previous page and to select the items of that page.
                  May be the selection syntax is not correct.
                  In fact I have another challenge here. I also need to loop whether the
                  previous page do contains the "myFrame" or not. If it is not keep going
                  back (or may be forward- I will check the condition) to find a page with
                  "myFrame" textFrame.
                  if(!(myDoc.pages[i].textFrames.itemByName("myFrame")!=null))
                  myPreviousPage.textFrames.itemByName("myFrame").insertionPoints.item(-1).properties
                  = { appliedCharacterStyle : "myCharacterStyle", contents:myText}; //ERROR
                  ON THIS LINE
                  else{
                  var myText="someothertext";
                  Time to brush up my JS skills.
                  --PC
                  • 7. Re: Select previous page items or next page items (IDCS3)
                    PankChat Level 1
                    Ok Fine!!!! if I use Next page option instead of previous page
                    (Strange!!!!!!! Does ID looks forward and ignore back pages in this case
                    or what?) it works and of course fails for the last page !!!!! Time to
                    resolve the loop issue.
                    myNextPage.textFrames.itemByName("sections").insertionPoints.item(0).properties
                    TIA,
                    --PC
                    • 8. Re: Select previous page items or next page items (IDCS3)
                      PankChat Level 1
                      Hello again,
                      Kasyan's suggestion
                      var myPreviousPage=mydoc.pages[i].previousItem(myPage);
                      do not prompt for any error if selected first page.
                      Harbs suggestion though prompts error if selected first page (obviously there is no  previous page)
                      var myPreviousPage = doc.pages.item(page.documentOffset+1);
                      but both of them fails if I try
                      = { appliedCharacterStyle : "myCharacterStyle", contents:myText}; //Object is invalid
                      but works for the next page (at least Kasyan's suggestion: not tested Harbs idea).
                      myNextPage.textFrames.itemByName("myFrame").insertionPoints.item(0).properties
                      I beleive this has nothing to do with insertionPoints(-1) I am trying for myPreviousPage case and ID do look for back pages???????? Simply getting nuts.
                      Any ideas???
                      --PC
                      • 9. Re: Select previous page items or next page items (IDCS3)
                        PankChat Level 1
                        Just to clear the confusion
                        myPreviousPage.textFrames.itemByName("myFrame").insertionPoints.item(-1).propert ies
                        Even the selected page is not first page and previous page has textframe labelled "myFrame".
