1 Reply Latest reply on Jun 23, 2010 9:53 AM by rajendrajagad
    How to Import a Custom Class Using CS4 Flash Professional
    rajendrajagad
      Hello,
      I created two custom class called fooClass.as and HelloClass.as
      Then I want to import both of these Custom Classes in my WorkSpace.fla file
      so I do the following I open up my WorkSpace.fla file
      Press F9 to open up the actionScript panel in FrameOne LayerOne
      and I type in
      import fooClass
      import HelloClass
      then I want to start using these two classes so I do the following
      var work:fooClass = new fooClass();
      var space:HelloClass = new HelloClass();
      Technically speaking when I type in
      var work: I should see list of classes inside the library including my custom Class fooClass and HelloClass
      However after the colon I see other build in classes but not fooClass.
      It works in CS5 but not CS4.
      How do I get to work it in CS4 so that I can use the custom class I created to show up in the library.
      R
