2 Replies Latest reply on Jun 17, 2010 2:42 PM by rashmin.d
    Problem with multiple images
    jatin4rise
      I just have a question to ask , before i go against good programming practise.
      I have more than 20 images which uniquely refers to markers. So do i have to uniquely
      create an instance of Class and Embed a source of each image, 20 times, as i do for a single image.
      [Embed(source="images/abcd.png")]
      private var hotel:Class;
      Thanks for you feedback.
        • 1. Re: Problem with multiple images
          rtalton Level 4
          If they are small, go ahead and embed them. Otherwise, load them only when needed.
          • 2. Re: Problem with multiple images
            rashmin.d Level 1
            hi......
            u mention that 20 pics..... see its big or not... but it is not good that i embed 20 pics. in file... it make you swf file big n takes more time then dynamic way.....So, best way to do it is put in one folder n rename in serialize manner....n load them in for loop using Loader Class.. one by one.. it make 3 line code....... OR    if u cann't do the rename then Use the XML file to read the name n load images...
            i will hope it will help u....
