0 Replies Latest reply on Jun 17, 2010 8:46 AM by yuriyyyz
    Issue with Flex WSDL Proxy Generator created classes
    yuriyyyz Level 1
      Hello ALL,
      I have created strongly typed classes with a webservice WSDL and now trying to use them to send a request to the web service.
      Here is a body of the WS request imported from the same WSDL with SoapUI:
               <ns:Journey>
                  <ns:Origin LocationCode="?" CodeContext="?">?</ns:Origin>
                  <ns:Destination LocationCode="?" CodeContext="?">?</ns:Destination>
                  <ns:DateTime>
                     <!--Optional:-->
                     <ns:OutBound>
                        <!--You have a CHOICE of the next 2 items at this level-->
                        <ns:DepartureDateTime WindowBefore="?" WindowAfter="?" CrossDateAllowedIndicator="?">?</ns:DepartureDateTime>
                        <ns:ArrivalDateTime WindowBefore="?" WindowAfter="?" CrossDateAllowedIndicator="?">?</ns:ArrivalDateTime>
                     </ns:OutBound>
                     <!--Optional:-->
                     <ns:Inbound>
                     </ns:Inbound>
                  </ns:DateTime>
               </ns:Journey>
      Here is how a valid XML request look like:
        <Journey>
          <Origin LocationCode="AAA" CodeContext="DDD"/>
          <Destination LocationCode="BBB" CodeContext="DDD"/>
          <DateTime>
            <OutBound>
                <DepartureDateTime WindowAfter="1">2010-02-18T06:43:00</DepartureDateTime>
            </OutBound>
          </DateTime>
        </Journey>
      DepartureDateTime class is defined as TimeInstantType() and has the following properties defined:
      * properties
      private var _internal_WindowBefore : int;
      private var _internal_WindowAfter : int;
      private var _internal_CrossDateAllowedIndicator : Boolean;
      All three DepartureDateTime XML tag attributes are represented here with  WindowBefore, WindowAfter and CrossDateAllowedIndicator variables, so I am able to set the attributes.
      What I don't understand is how do I set the actual Tag Value as represented above with "2010-02-18T06:43:00" data?
      Thank you , George
