13 Replies Latest reply on Aug 7, 2010 8:05 PM by mordsm
    error 103
    alfonsofonso Level 1
      hi, when compiling I get this error:
      Unexpected or unknown element or attribute in the application descriptor file.
      /Users/admin18/Desktop/distriboid/android/distriboid-app.xml(4): error 103: application.version is an unexpected element/attribute
      any ideas?
      thanx a lot
      alfonsofonso
        • 1. Re: error 103
          ah! sorry!
          I'm at the air 2.5 prerelease program, and using that, trying to get an apk
          • 2. Re: error 103
            mordsm Level 1
            Change version into versionNumber and it will work
            Moshe
            • 3. Re: error 103
              a tengo
              • 4. Re: error 103
                jasonhr13 Level 1
                i changed version to versionNumber, did not work then i get the same error but it says versionNumber is unexpected.
                • 5. Re: error 103
                  rkewlani Level 2
                  Hi Jason,
                  Can you share your application descriptor file i.e. application.xml ?
                  Rohit
                  • 6. Re: error 103
                    mordsm Level 1
                    Can you send your _app.xml + the error you get
                    • 7. Re: error 103
                      jasonhr13 Level 1
                      ok the error is the above error and the xml is
                      <?xml version="1.0" encoding="utf-8" standalone="yes"?>
                      <application xmlns="http://ns.adobe.com/air/application/2.5">
                          <id>com.thwebco.heyy</id>
                          <versionNumber>1.0.0</versionNumber>
                          <filename>things</filename>
                          <description></description>
                          <!-- To localize the description, use the following format for the description element.
                              <description>
                                      <text xml:lang="en">English App description goes here</text>
                                      <text xml:lang="fr">French App description goes here</text>
                                      <text xml:lang="ja">Japanese App description goes here</text>
                              </description>
                          <name>things</name>
                          <!-- To localize the name, use the following format for the name element.
                              <name>
                                      <text xml:lang="en">English App name goes here</text>
                                      <text xml:lang="fr">French App name goes here</text>
                                      <text xml:lang="ja">Japanese App name goes here</text>
                              </name>
                          <copyright></copyright>
                          <initialWindow>
                              <content>things.swf</content>
                              <systemChrome>standard</systemChrome>
                              <transparent>false</transparent>
                              <visible>true</visible>
                              <fullScreen>false</fullScreen>
                              <autoOrients>false</autoOrients>
                              <aspectRatio>portrait</aspectRatio>
                              <renderMode>auto</renderMode>
                              <maximizable>true</maximizable>
                              <minimizable>true</minimizable>
                              <resizable>true</resizable>
                          </initialWindow>
                          <customUpdateUI>false</customUpdateUI>
                          <allowBrowserInvocation>false</allowBrowserInvocation>
                          <icon></icon>
                          <version>1.0.0</version>
                      </application>
                      • 8. Re: error 103
                        jasonhr13 Level 1
                        does it mater that its not really a full app its just a blank screen? I was just trying to get familiar with the transfer process
                        • 9. Re: error 103
                          _divy Level 1
                          You have duplicate versionNumber nodes. Delete the bottom one.
                          • 10. Re: error 103
                            thilgen Level 4
                            You need to also delete <version> - that tag is not supported in AIR 2.5.
                            Chris Thilgen
                            AIR Engineering
                            • 11. Re: error 103
                              mordsm Level 1
                              I still see 3 lines from bottom version -> 103 is unexpected
                              element/Attribute
                              moshe
                              • 12. Re: error 103
                                thilgen Level 4
                                moshe
                                Not sure what you are saying...
                                could you please post a complete copy of your latest app-descriptor.xml so we can take a look?
                                Chris Thilgen
                                AIR Engineering
                                • 13. Re: error 103
                                  mordsm Level 1
                                  I sent to the wrong email
                                  sorry for that
                                  nice week for you all
                                  moshe
