4 Replies Latest reply on Jun 17, 2010 8:53 PM by sstanleyau
    help with hyperlinks in applescript indesign cs4
    conyip
      Hi there i am hoping that someone can help:
      I have written an applescript script to search a document, when the search text string matches the files loaded in a list from an external folder, a hyper link is created to this external file. see below:
      set the_folder to choose folder
      tell application "Finder"
      set files_list to every file of folder the_folder whose name extension is "pdf"
      end tell
      tell application "Adobe InDesign CS4"
      repeat with FileRef in files_list
      set FileName to name of FileRef
      set find text preferences to nothing
      --Search the document.
      set find what of find text preferences to FileName
      --Set the find options.
      set case sensitive of find change text options to false
      set include footnotes of find change text options to true
      set include hidden layers of find change text options to false
      set include locked layers for find of find change text options to false
      set include locked stories for find of find change text options to false
      set include master pages of find change text options to false
      set whole word of find change text options to false
      tell active document
      set myFoundItems to (find text) as string
      if FileName = myFoundItems then
      set FileNewName to name of FileRef as string
      set TxtName to name of FileRef
      set TheURL to "files:files/" & FileNewName
      try
      set TheH to make hyperlink URL destination with properties {name:TxtName, destination URL:TheURL}
      on error
      set TheH to hyperlink URL destination TxtName
      end try
      set TheHSName to "HS" & TxtName
      set TheHS to make hyperlink text source with properties {name:myFoundItems, source text:myFoundItems, hidden:false} <<error on this line
      make new hyperlink with properties {destination:TheH, source:TheHS, visible:false}
      end if
      end tell
      end repeat
      end tell
      however I keep getting an error: "Adobe InDesign CS4 got an error: Can't get hyperlink text source text expected but got \"applescript.pdf\"."
      I can not figure it out as the text source is a string..
      thanks
      Keith
        • 1. Re: help with hyperlinks in applescript indesign cs4
          sstanleyau Level 4
          The source text of a hyperlink text source requires a reference to the the bit of text you want to be the source, not its contents.
          • 2. Re: help with hyperlinks in applescript indesign cs4
            conyip Level 1
            Thanks a lot for the reply,, this is so frustrating, and sorry for not being able to see it, but can you give an example..
            keith
            • 3. Re: help with hyperlinks in applescript indesign cs4
              sstanleyau Level 4
              This is untested, but should get you close:
              end tell
              set myFoundItems to find text -- search; returns list of object references
              if myFoundItems is not {} then
              -- make a single destination
              set TheURL to "files:files/" & FileName
              if not (exists hyperlink URL destination FileName) then
              set TheH to make hyperlink URL destination with properties {name:FileName, destination URL:TheURL}
              else
              set TheH to hyperlink URL destination FileName
              end if
              repeat with i from 1 to count of myFoundItems
              set TheHSName to "HS" & FileName & "-" & i -- if you don't want the default name, you have to make it unique
              set TheHS to make hyperlink text source with properties {name:TheHSName, source textitem i of myFoundItems), hidden:false}
              end repeat
              end if
              end tell
              end repeat
              end tell
              • 4. Re: help with hyperlinks in applescript indesign cs4
                sstanleyau Level 4
                Actually, while that fixes your hyperlink stuff, you have problems earlier on with your file names and URLs -- you can't build URLs like that. Try something like this:
                set files_list to name of every file of folder the_folder whose name extension is "pdf"
                set url_list to URL of every file of folder the_folder whose name extension is "pdf"
                end tell
                repeat with j from 1 to count of files_list
                set FileName to item j of files_list
                set TheURL to item j of url_list
                else
                end if
                set TheHS to make hyperlink text source with properties {name:TheHSName, source text: (item i of myFoundItems), hidden:false}
                end repeat
                end if
                end tell
                end repeat
                end tell
