1 Reply Latest reply on Jun 24, 2010 1:15 AM by nishadmusthafa
    Creating a new project using Flash Builder 4
    toby007 Level 1
      Hi there
      I have started to create a new project - am very much in a learning phase at present (have been a long time CF developer).
      Here are the steps that I have taken so far:
      I have created the project.
      When starting the project I decided to select ColdFusion as the application server (stepped through the remaining steps - that part was all fine).
      I then selected the option to connect to the datasource.  This part was all fine.
      I connected to the datasource and the correct table and I have a CFC created which is pulling the information correctly.
      I created a datagrid using design mode.
      I then pasted one of the services onto the datagrid to display data - (Again this is working well).
      From the data grid I generated a details form.
      I can select a record in the datagrid and the information appears in the details form.
      At the bottom of the form there is an submit button.
      If I change any information it does show in the datagrid as being changed but it is not changed in the database.
      My question is - what do I need to do to have the information changed in the database table.
      Thanks in advance.
