3 Replies Latest reply on Jun 18, 2010 11:25 AM by VRPDeveloper
    List Transitions
    demkalkov
      I've got a List that has 3 states with different layouts.
      1st - Horizontal
      2nd - Vertical
      3rd - Horizontal
      All of the states have its own ItemRenderer with its own size and content.
      How can I apply transitions to list, so that items moved smoothly?
        • 1. Re: List Transitions
          VRPDeveloper Level 3
          You can use transitions in this way
          <mx:transitions>
                  <!-- A transition for changing from any state to any state. -->
                  <mx:Transition id="myTransition" fromState="horizontal" toState="vertical">
                      <!-- Define a effect as the top-level effect.-->
                  </mx:Transition>
              </mx:transitions>
          and so ... again use from vertical to horizontal....
          Hope it will help you...
          • 2. Re: List Transitions
            demkalkov Level 1
            <s:states>
                    <s:State name="List"/>
                    <s:State name="Tile"/>
                    <s:State name="Details"/>
                </s:states>
            <s:List id="ProgramsList"  width="100%" height="100%" dataProvider="{dataSource2}"
                        borderVisible="false"
                        itemRenderer="ItemRenderers.ProgramList"
                        itemRenderer.Details="ItemRenderers.ProgramDetails"
                        itemRenderer.Tile="ItemRenderers.ProgramTile"
                        changing="setCurrentState('Details')"
                        x="5" y="10"
                        useVirtualLayout="false">
                        <s:layout>
                            <s:VerticalLayout/>
                        </s:layout>
                        <s:layout.Tile>
                            <s:TileLayout horizontalGap="10"/>
                        </s:layout.Tile>
                        <s:layout.Details>
                            <s:VerticalLayout verticalAlign="middle" horizontalAlign="center" />
                        </s:layout.Details>
                    </s:List>
            <s:transitions>
                    <s:Transition id="SmoothMove">
                        <s:Parallel target="ProgramsList">
                            <s:Resize duration="500"/>
                            <s:Move duration="500" />
                        </s:Parallel>
                    </s:Transition>
            </s:transitions>
            But it plays no transitions at all!
            • 3. Re: List Transitions
              Oh... You need to bind ProgramList with Transition in Target.... You have directly used <s:Parallel target="ProgramsList"> but it should be something like this
              <s:Parallel target="{ProgramsList}">
              Hope this will solve your problem
