1 Reply Latest reply on Jun 18, 2010 8:01 AM by Colin Brougham
    Change sequence fps?
    mr.miko
      My main sequence FPS is 50fps and it's causing the other video to move strangely.  I have already painstakingly placed all the audio and video- is it possible to change the sequence frame rate- or is it possible to create a new sequence with a different frame rate in the same project and move all work from the fast sequence to the slower sequence?  Thanks.
        • 1. Re: Change sequence fps?
          Colin Brougham Level 6
          Depends on which version of Premiere Pro you're using. If it's CS4 or above, create a new sequence as you want, copy everything from the original sequence, and paste into the new one. Edit.
          If you're in CS3 or lower, you can import your old project into a new one that is set up properly.
