2 Replies Latest reply on Jun 18, 2010 2:52 PM by Warentester
    Button enabled="false" & moving Objects.
    Warentester
      Hello everyone,
      I want a button, which is ,
      enabled="false"
      to only change to
      enabled="true"
      if i move an object to a special location on the screen.
      For simplicity in the example I sayed the special location should be the location of the button.
      When i move my object (an unlabeled button) to the button "Test1" then the button should be enabled="true".
      However, in my broken programming code, whenever i move the unlabeld button, the "Test1" Button becomes enabled="true".
      I have no idea why ?
      It would be great if anyone could help me
      Markus
      Here is the Code.
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Declarations>
              <!-- Platzieren Sie nichtvisuelle Elemente (z. B. Dienste, Wertobjekte) hier -->
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                      area1.addEventListener(KeyboardEvent.KEY_DOWN, moveTextArea);
                      var timer:Timer = new Timer(50);
                      timer.delay=100;
                      timer.repeatCount=0;
                      timer.addEventListener(TimerEvent.TIMER, timeListener);
                      timer.start();
                  public function timeListener(e:TimerEvent):void
                  public function dummy()
                      if((area1.x == test1.x) && (area1.y == test1.y))
                              test1.enabled="true";
                          else
                              test1.enabled="false";
                  public function moveTextArea(e:KeyboardEvent):void
                      if(e.keyCode == Keyboard.RIGHT)
                          area1.x += 20;
                      if(e.keyCode == Keyboard.LEFT)
                          area1.x -= 20;
                      if(e.keyCode == Keyboard.UP)
                          area1.y -= 20;
                      if(e.keyCode == Keyboard.DOWN)
                          area1.y += 20;
                      dummy();
          </fx:Script>
          <s:Button x="20" y="20" label="Test1" id="test1" enabled="false"/>
          <s:Button x="60" y="60" id="area1" />
      </s:Application>
