13 Replies Latest reply on Jun 20, 2010 1:54 PM by Ann Bens
    No audio in DV Clip on CS5. Audio plays in QT.
    RobSher1 Level 1
      PP Windows 7, 6GB, I7, Nvidia 480
      Copied project from Mac CS4 to new PC running CS5. Audio plays fine on MAC in CS4 PP.
      The movie is  720 x 480 (1.2121), 29.97 fps, 48000 Hz - 16-bit - Mono and plays with the audio in QuickTime.
      The files were converted by a TV producer as .mov file types where he had to spit them out into 2GB extensions for a FAT32 drive. Not sure what you would call them (like a split zip on PC), but there is a primary file i.e. TAPE ONE-v.mov and then 6 files like TAPE ONE-1-v.mov, TAPE ONE-2-v.mov, etc.
      There is no audio in the Project or Source windows and they create two empty mono audio tracks on the timeline.
      Any suggestions would be greatly appreciated as I need to finish a trailer this weekend.
        • 1. Re: No audio in DV Clip on CS5. Audio plays in QT.
          the_wine_snob Level 9
          It could be the AIFF Audio in those MOV files. I have had issues with that format/CODEC and ended up converting to PCM/WAV in Audition.. What is the Audio Stream of the files?
          • 2. Re: No audio in DV Clip on CS5. Audio plays in QT.
            RobSher1 Level 1
            Not sure how to tell what the audio stream is. Can you give me exact details to determine what they are.
            I deleted the cfa and pek files after closing PP and the project ran through the Conforming sequence when I reopened the project. I can see the cfa and pek files for those clips and the cfa files are all around 500 MB.
            Still don't have the audio.
            Rob
            • 3. Re: No audio in DV Clip on CS5. Audio plays in QT.
              Rob,
              One can use several utilities, like G-Spot, or MediaInfo, or even QT Pro (Ctrl+J) to get the specs. of most AV files.
              As a test, do you have a program, like Adobe Audition, or the free audio-editor, Audacity? If so, rip the Audio from the MOV files, and then do a Save_As, choosing PCM/WAV 48KHz 16-bit, and Import that into your PrPro Project. Does this WAV file play fine?
              • 4. Re: No audio in DV Clip on CS5. Audio plays in QT.
                RobSher1 Level 1
                I did an Apple J in QT 7 Pro on my mac.
                Video: DV/DVCPRO - NTSC
                Audio: Integer (Little Endian)
                I'll convert the audio if I have to, but don't see why CS5 works the same as CS4 where the audio is included with the video.
                Are there any log files on the PC that I can check to see what it's doing?
                Thanks.... Rob
                • 5. Re: No audio in DV Clip on CS5. Audio plays in QT.
                  RobSher1 Level 1
                  I created a wave file on the Mac and have imported them to CS5 on the PC. It's a hassle because original clip time code is different than the audio file.
                  I'm baffled and frustrated that CS5 can't import the audio with the video file when it works fine on CS4. I've tested the video on both a Mac and PC running CS4 and it works great. This is really strange. Guess I'll have to log a support call with Adobe.
                  Any other suggestions would be greatly appreciated. Rob
                  • 6. Re: No audio in DV Clip on CS5. Audio plays in QT.
                    Colin Brougham Level 6
                    Yeah, that's not going to get you anywhere. Support seems to know less than we (i.e. real users) actually do. If we can't solve it, I can virtually guarantee that they can't. I don't like throwing Adobe under the bus, but on this aspect, they pretty much suck.
                    The fact that you can use these in CS4 but not in CS5 would, IMO, be due to the 64-bit nature of Premiere Pro CS5. Right now, I think that QuickTime support might be in a state of flux, as QT is still 32-bit, and Adobe has implemented some brute-force means of making QTs work in Premiere Pro CS5. No guarantees, but this would be my estimation.
                    You might try running the files through QuickTime Pro to export them to a new DV file, or perhaps MPEG Streamclip (Google it; it's free). There might just be some variations of QT files that won't work in CS5, at least at the present time.
                    • 7. Re: No audio in DV Clip on CS5. Audio plays in QT.
                      RobSher1 Level 1
                      Thanks Colin...
                      I exported the audio and added them to a new CS5 full sequence, then exported to P2 Movie NTSC DVCPro50. I was able to import them and the audio works fine.
                      I'll try your suggestion to export the sequences in QT Pro to a new DV file and see if that works.
                      Another interesting feature is that the CS5 project always prompts for the file location of the .mov's when I restart PP.
                      At least I can continue working now.
                      Thanks all....
                      • 8. Re: No audio in DV Clip on CS5. Audio plays in QT.
                        This is almost always a case of the Project file (PRPROJ) loosing the link to the Assets. One common situation is when the Assets are on an external, and the OS assigns a different drive letter, each time that the external is plugged in. It can also happen on networked drives too.
                        The "trick," if the Assets are on an external, is to assign a constant drive letter to that external in the OS. I do this for all of my externals on the PC, and just assign that same drive letter in the OS of all of my computers, so if I plug in Z:\, it is always seen as Z:\, regardless of which computer is being used. I do not know about Mac drive letter assignment.
                        • 9. Re: No audio in DV Clip on CS5. Audio plays in QT.
                          RobSher1 Level 1
                          Hi Bill,
                          Great tip about maintaining a consistent external drive letter.
                          Mine looks like a bug because the file is on my C:\ drive in the same folder as the project.
                          As a side question (probably not kosher)
                          I don't have contact with my camera guy anymore and wonder if you or someone else knows what he used to convert the HD footage to a multi-file mov?
                          Don't know which camera, but the film is Sony DVCAM. I know he converted the tape from HD to SD.
                          I'm converting the files in QT Pro to one QT movie, but will still log a support call tomorrow about both issues.
                          Thanks again for your help,
                          Rob
                          • 10. Re: No audio in DV Clip on CS5. Audio plays in QT.
                            Rob,
                            QT Pro has a Properties function (Ctrl+J on the PC), that should give you most of the details of those original files. The only two utilities that I use are G-Spot and MediaInfo, but do not think that they run on a Mac. Also, while G-Spot is great with AVI and MPEG, it falls down a bit with MOV and WMV's.
                            • 11. Re: No audio in DV Clip on CS5. Audio plays in QT.
                              RobSher1 Level 1
                              Bill, I think you've solved the mystery in terms of where CS5 is going wrong.
                              Using MediaInfo, I was able to see there are three audio tracks.
                              Audio #1: PCM, 1 channel, Bit Rate 768 Kbps, Sample Rate 48 KHz, Stream size 330 MiB that spans all six video files
                              Audio #2: PCM, 1 channel, Bit Rate 768 Kbps, Sample Rate 48 KHz, Stream size 330 MiB that spans all six video files
                              Audio #3: PCM, Muxing mode: DV, Bit rate 1536, 2 channels, Stream size 0 Byte
                              PP must be importing the empty Audio #3.
                              More info to help Adobe fix this in some future release (no comment -)
                              General
                              Complete name                    : C:\Users\Rob\Videos\Joyce\SAGE TAPE four-v.mov
                              Format                           : QuickTime
                              Format/Info                      : Original Apple specifications
                              File size                        : 2.00 GiB
                              Duration                         : 1h 0mn
                              Overall bit rate                 : 4 768 Kbps
                              Encoded date                     : UTC 2008-08-02 22:52:16
                              Tagged date                      : UTC 2008-08-02 23:52:45
                              Writing library                  : Apple QuickTime
                              Original source medium           : 001
                              Media/UUID                       : B423FA31-C63A-41A1-994B-4F84E45A2265
                              ©TSC                             : 2997
                              ©TSZ                             : 100
                              Video
                              Format                           : DV
                              Codec ID                         : dvc
                              Duration                         : 1h 0mn
                              Bit rate mode                    : Constant
                              Bit rate                         : 24.4 Mbps
                              Width                            : 704 pixels
                              Original width                   : 720 pixels
                              Height                           : 480 pixels
                              Display aspect ratio             : 16:9
                              Frame rate mode                  : Variable
                              Frame rate                       : 29.970 fps
                              Minimum frame rate               : 27.000 fps
                              Maximum frame rate               : 29.970 fps
                              Standard                         : NTSC
                              Color space                      : YUV
                              Chroma subsampling               : 4:1:1
                              Bit depth                        : 8 bits
                              Scan type                        : Interlaced
                              Bits/(Pixel*Frame)               : 2.411
                              Stream size                      : 12.1 GiB
                              Encoding settings                : ae mode=manual / wb mode=one push / white balance= / fcm=manual focus
                              Language                         : English
                              Encoded date                     : UTC 2008-08-02 23:52:44
                              Source                           : SAGE DV\SAGE TAPE four-6-v.mov
                              Source_Info                      : Missing
                              Audio #1
                              Format                           : PCM
                              Format settings, Endianness      : Little
                              Format settings, Sign            : Signed
                              Codec ID                         : sowt
                              Duration                         : 1h 0mn
                              Bit rate                         : 768 Kbps
                              Channel(s)                       : 1 channel
                              Sampling rate                    : 48.0 KHz / 48.0 KHz / 48.0 KHz / 48.0 KHz / 48.0 KHz / 48.0 KHz / 48.0 KHz
                              Stream size                      : 330 MiB (16%)
                              Language                         : English
                              Encoded date                     : UTC 2008-08-02 23:52:45
                              Audio #2
                              Format                           : PCM
                              Codec ID                         : sowt
                              Duration                         : 1h 0mn
                              Bit rate                         : 768 Kbps
                              Language                         : English
                              Audio #3
                              Format                           : PCM
                              Muxing mode                      : DV
                              Muxing mode, more info           : Muxed in Video #1
                              Duration                         : 1h 0mn
                              Bit rate                         : 1 536 Kbps
                              Channel(s)                       : 2 channels
                              Bit depth                        : 16 bits
                              Stream size                      : 0.00 Byte (0%)
                              Menu
                              Language                         : English
                              • 12. Re: No audio in DV Clip on CS5. Audio plays in QT.
                                Interesting. To get your Project out the door, can you rip the Audio from the muxed streams, and then Save_As PCM/WAV 48KHz 16-bit, and Import that?
                                Just thinking here, and good luck,
                                hunt
                                • 13. Re: No audio in DV Clip on CS5. Audio plays in QT.
                                  Next time put your material anywhere but the C-drive.
                                  C-drive is for OS and programms, nothing else.
