1. Re: Reading Excel file from another site
Dan Bracuk Jun 19, 2010 3:50 PM (in response to WebolutionDesigns)Use cfspreadsheet to read it from it's current location.
2. Re: Reading Excel file from another site
WebolutionDesigns Jun 19, 2010 9:50 PM (in response to Dan Bracuk)Unfortunately, this client is not in my hosting environment, which is CF9. They are on an inferior host which has them on CF6 (yuck!).
3. Re: Reading Excel file from another site
Dan Bracuk Jun 20, 2010 4:56 AM (in response to WebolutionDesigns)Find Ben Nadel's poi for getting coldfusion to play with excel. I know it works on v7. It might work on v6 also.
4. Re: Reading Excel file from another site
WebolutionDesigns Jun 22, 2010 6:45 AM (in response to Dan Bracuk)Thanks. I have used his utility in the past and loved it. I am having difficulties in getting it to read a remote file though.
5. Re: Reading Excel file from another site
tclaremont Jun 22, 2010 9:58 AM (in response to WebolutionDesigns)Can you programmically retrieve it using CFFTP?
Here is a simple example...
<cfftp connection="#session.sessionID#" action="getfile" remotefile="#form.myget#" localfile="#scriptdir#/stuff/#form.myget#" transfermode="binary"
timeout="30" retrycount="3" stoponerror="no" failifexists="no">
<cfif cfftp.errorcode is not 0>
<cfoutput>
Attempt to get #form.myget# failed.
#cfftp.errortext#
</cfoutput>
<cfelse>
Got <cfoutput>#form.myget#</cfoutput> OK.
</cfif>
<cfset form.myget=""> -
6. Re: Reading Excel file from another site
ilssac Jun 22, 2010 9:45 AM (in response to WebolutionDesigns)<cfhttp....> can be used to get excel file nearly the same as it can get the HTML content.
The documentation should give you the details.
7. Re: Reading Excel file from another site
Dan Bracuk Jun 22, 2010 12:49 PM (in response to WebolutionDesigns)What sort of difficulties are you having? File not found? Not enough permission?
8. Re: Reading Excel file from another site
WebolutionDesigns Jun 22, 2010 1:29 PM (in response to Dan Bracuk)I was able to successfullly download the excel file using cfhttp. (Thanks, Ian).
Now I am attempting to use Ben Nadel's POI utility (which I have used before with success) to read it. I am running into the following error...
org.apache.poi.poifs.filesystem.POIFSFileSystem
What does this mean? Is it because their host is not on a high enough level?
9. Re: Reading Excel file from another site
WebolutionDesigns Jun 28, 2010 9:36 AM (in response to WebolutionDesigns)I was able to successfully retrieve and manipulate the data from the external page using cfhttp and parsing through the filecontent to get the info I needed. Thanks for your assistance.
