Trunk build failure
clint.modien Jun 18, 2010 4:17 PMChecked out the trunk today to build the latest and I received a build failure error when running mvn package.
Here's the error:
Running de.bokelberg.flex.parser.TestPackageContent
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running de.bokelberg.flex.parser.TestInterface
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Tests run: 128, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar {execution: default-jar}]
[INFO] [license:check {execution: default}]
[INFO] Checking licenses...
[INFO] ------------------------------------------------------------------------
[INFO] Building Adobe Flex PMD RuleSet API
[INFO] task-segment: [package]
[WARNING] POM for 'jaxen:jaxen:pom:1.1.1:compile' is invalid.
Its dependencies (if any) will NOT be available to the current build.
[INFO] [dependency:unpack-dependencies {execution: unpack-test-resources}]
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/as3-parser/target/as3-parser-1.2-SNAPSHOT.jarto
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/target/test/generated-resources
with Includes **/*.as,**/*.mxml and excludes:null
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/as3-plugin-utils/target/as3-plugin-utils-1.2-SNAPSHOT.j arto
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/flex-pmd-files/target/flex-pmd-files-1.2-SNAPSHOT.jarto
[INFO] Unpacking /Developer/Web/Flex/adobe/flexpmd/flex-pmd-test-resources/target/flex-pmd-test-resources- 1.2-SNAPSHOT-resources.zipto
[INFO] [resources:resources {execution: default-resources}]
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] Copying 1 resource
[INFO] [compiler:compile {execution: default-compile}]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources {execution: default-testResources}]
[INFO] Copying 96 resources
[INFO] Copying 0 resource
[INFO] [compiler:testCompile {execution: default-testCompile}]
[INFO] Compiling 5 source files to /Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/src/test/java/com/adobe/ac/pmd/node s/utils/AsDocUtilsTest.java:[64,53] cannot find symbol
symbol : method computeParameterDoc(java.lang.String,java.lang.String)
location: class com.adobe.ac.pmd.nodes.utils.AsDocUtils
/Developer/Web/Flex/adobe/flexpmd/flex-pmd-ruleset-api/src/test/java/com/adobe/ac/pmd/file s/FileSetUtilsTest.java:[52,39] buildLogMessage(com.adobe.ac.pmd.files.IFlexFile,java.lang.String) has private access in com.adobe.ac.pmd.files.FileSetUtils
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor .java:715)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifec ycleExecutor.java:556)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor. java:535)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultL ifecycleExecutor.java:387)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleE xecutor.java:348)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java :180)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:328)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation failure
at org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:516)
at org.apache.maven.plugin.TestCompilerMojo.execute(TestCompilerMojo.java:102)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:490)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor .java:694)
... 17 more
[INFO] Total time: 20 seconds
[INFO] Finished at: Fri Jun 18 13:57:21 PDT 2010
[INFO] Final Memory: 72M/460M
