1 Reply Latest reply on Aug 23, 2007 11:50 AM by Captiv8r
    Adding recordings after the fact
    GShep
      Recording works just fine. But even with a high end mic and pre-amp prior to going to a Dell desktop PC, the noise (due to the Dell we are sure) is terrible! We have a way to do 'studio quality recordings' but then how can you get these in/matching things up. I was thinking that maybe one could run the demo in the studio on a quiet laptop, speak into the studio system to get the timing right, and then somehow bring those in. Is this a reasonable way to go? Better suggestions? Many thanks.
        • 1. Re: Adding recordings after the fact
          Hi GCSHEPH and welcome to our community
          Indeed this would be one approach to take. Basically, you can record with whatever you like. All you need is a resulting .MP3 or .WAV file. (The .WAV must be PCM encoded) You would then insert the audio clips into Captivate. This could occur in a variety of ways. One way would be to select the slide where you want the audio, then press F6 (or click Audio > Import...) and bring the clips in.
          Hopefully this helps... Rick
