5 Replies Latest reply on Jun 19, 2010 11:15 AM by Ned Murphy
    Second loader not working
    learner_7n Level 1
      The following action script for loader is working fine:
      var l:Loader=new Loader();
      addChild(l);
      l.load(new URLRequest("MyLogo.swf"));
      But when I added one more loader to it like the following...It doesn't show anything but gives an error:
      addChild(l);
      var 2:Loader=new Loader();
      addChild(2);
      2.load(new URLRequest("Plant.swf"));
      The error is: Syntax error: expecting identifier before 2.
      What does it mean and how to solve the problem?
      Regards.
        • 1. Re: Second loader not working
          Do not use a number as an instance name/variable.  In case you think the first is using a "1", it is not, it is a lower case L.
          • 2. Re: Second loader not working
            learner_7n Level 1
            Fantastic. It is fine both are working now. But the problem is one logo sits on another. So I can see only one logo after animation. I don't see any logo on my stage to re-position it on different locations unless I run my movie. Further help needed to resolve the problem. Since I am new to flash asking several questions. Please forgive me.
            Regards.
            • 3. Re: Second loader not working
              Set the x and y properties of your loaders to be where you want them...
              l.x = 100; // just an example
              l.y = 100;
              • 4. Re: Second loader not working
                learner_7n Level 1
                l.y = 100;
                Quite nice. Working great. Can I resize it through code? When I tried like the following the logo disappered completely.
                l.width =200;
                l.height =200;
                What is the correct way?
                Best regards.
                • 5. Re: Second loader not working
                  You have to wait until the file being loaded is fully loaded before you can try to change width/height properties of the Loader--without content, the loader has no width/height.  You'll need a listener to listen for the INIT event of the contentLoaderInfo property of the Loader.
                  l.contentLoaderInfo.addEventListener(Event.INIT, growLoader);
                  function growLoader(evt:Event):void {
                       l.width = 200;
                       l.height = 200;
                  Please mark this posting as answered, and if you have new questions, start new postings.  It helps others looking for help when you stick to the topic in the title.
