3 Replies Latest reply on Aug 15, 2007 2:19 PM by Newsgroup_User
    Rollovers, how do you do it in CS3?
    proodzilla
      Thanks.. Trying to do it but can't figure it out... I know I did it before in older Image Ready.
        • 1. Re: Rollovers, how do you do it in CS3?
          Level 7
          There are a variety of ways to do this and the Fireworks Help Files talk
          about several. Here's an excerpt from the FW help files:
          Creating a simple rollover
          A simple rollover swaps in the frame directly under the top frame and
          involves only one slice.
          To attach a simple rollover to a slice:
          1. Ensure that the trigger object is not on a shared layer. For more
          information, see Sharing layers.
          2. Select Edit > Insert > Slice to create a slice on top of the trigger
          object.
          3. Create a new frame in the Frames panel by clicking the New/Duplicate
          Frame button.
          4. Create, paste, or import an image to use as the swap image on the new
          frame.
          Position the image beneath the slice you created in step 2, which is
          still visible even though you're in Frame 2. Slices are visible across
          all frames.
          5. Select Frame 1 in the Frames panel to return to the frame that has
          the original image.
          6. Select the slice and place the pointer over the behavior handle. The
          pointer changes to a hand.
          Note: You can select the slice while in any frame.
          7. Click the behavior handle and select Simple Rollover from the menu.
          8. Click the Preview tab and test the simple rollover, or press F12 to
          preview it in a browser.
          If you access the hlep files directly, there are illustrations to help
          out as well.
          HTH
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          Extending Knowledge, Daily
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          news://forums.macromedia.com/macromedia.fireworks
          news://forums.macromedia.com/macromedia.dreamweaver
          • 3. Re: Rollovers, how do you do it in CS3?
            Level 7
            proodzilla wrote:
            > Thanks a lot!
            You're quite welcome.
