3 Replies Latest reply on Jun 20, 2010 11:45 PM by Ianvn.za
    SVG path data assigned to Sprite
    Ianvn.za
      I'm trying to draw svg path data that gets passes to my flex file using XML.
      I have a path in the following format:
      "m 264 273 l 264 326 c 273 320 279 311 279 300 c 279 289 273 279 264 273 z"
      I have tried decoding the path and drawing it on the sprite by using the normal moveto, curveto and lineto functions of the sprite.graphics object.
      I am having problems drawing perfect curves.
      I came across spark.primitives.Path which accepts svg paths as stated above, but I'm struggling to find a way to assign that path to the sprite I'm trying to draw.
      Is there a way to assign this to a sprite?
        • 1. Re: SVG path data assigned to Sprite
          David_F57 Level 5
          hi,
          try this little application... it may help you
          David.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Declarations>
          <s:SolidColorStroke id="defaultStroke" color="{NormColor}" weight="2" alpha="0.9"/>
          <s:SolidColor id="defaultFill" color="{NormColor}" alpha="0.8"/>
          </fx:Declarations>
          <fx:Script>
          <![CDATA[
          import mx.core.IVisualElement;
          import mx.events.FlexEvent;
          import spark.components.Group;
          import spark.core.SpriteVisualElement;
          import spark.primitives.Path;
          [Bindable]private var NormColor: int = 0x00FF00;
          [Bindable]private var OverColor: int = 0x55FF55;
          private var mySprite:SpriteVisualElement = new SpriteVisualElement();
          private var myGroup:Group = new Group();
          private var myPath:Path = new Path();
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          myGroup.verticalCenter=0;
          myGroup.horizontalCenter=0;
          myGroup.width=40;
          myGroup.height=40;
          myPath.fill=defaultFill;
          myPath.stroke=defaultStroke;
          myGroup.addElement(myPath);
          this.addElement(mySprite as IVisualElement);
          mySprite.width = 40;
          mySprite.x=100;
          mySprite.y=100;
          mySprite.addChild(myGroup as DisplayObject);
          protected function button1_clickHandler(event:MouseEvent):void
          myPath.data="M6.115,27.036L0,18l6.115-8.98v5.972c5.896,0,8.856-2.986,8.856-9.109H9.051L18, 0l8.966,5.883"+
          "h-5.972c0,6.123,2.986,9.109,9.059,9.109V9.02L36,18l-5.947,9.036v-6.072c-6.072,0-9.059,3.0 36-9.059,9.159h5.972L18,36"+
          "l-9.152-5.877h6.124c0-6.123-3.062-9.159-8.856-9.159V27.036z";
          </fx:Script>
          <s:Button x="10" y="10" label="Add Path" click="button1_clickHandler(event)"/>
          </s:Application>
          • 2. Re: SVG path data assigned to Sprite
            Flex harUI Adobe Employee
            Flash.display.graphics.drawPath
            • 3. Re: SVG path data assigned to Sprite
              Ianvn.za Level 1
              Thanks David.
              That is exactly what I was looking for.
