1 Reply Latest reply on Jun 21, 2010 4:29 AM by Booya2nd
    Why the second loader doesn't work?
    learner_7n Level 1
      If I keep the first following action script (Adobe Flash CS4 Action Script 3) which is in BLUE it is workng fine. But If I keep the both action scripts which are in BLUE & RED. It shows nothing. What is the problem with the next one. Please do help.
      var l:Loader=new Loader();
      addChild(l);
      l.load(new URLRequest("MyLogo.swf"));
      l.x = 10;
      l.y = 100;
      l.contentLoaderInfo.addEventListener(Event.INIT, growLoader);
      function growLoader(evt:Event):void {
           l.width = 150;
           l.height = 150;
      var k:Loader=new Loader();
      addChild(k);
      k.load(new URLRequest("MyBanner.swf"));
      k.x = 200;
      k.y = 100;
      k.contentLoaderInfo.addEventListener(Event.INIT, growLoader);
           k.width = 500;
           k.height = 150;
      Thanks and regards.
        • 1. Re: Why the second loader doesn't work?
          Booya2nd
          Hi there,
          the error is caused by accidently overriding yout handler function   growLoader()  .
          You will have to define two handlers to solve the problem:
          addChild(l);
          l.x  = 10;
          l.y = 100;
          l.contentLoaderInfo.addEventListener(Event.INIT,  growLogoLoader);
          function growLogoLoader(evt:Event):void {
               l.width = 150;
               l.height = 150;
          addChild(k);
          k.x  = 200;
          k.y = 100;
          k.contentLoaderInfo.addEventListener(Event.INIT, growBannerLoader);
          function growBannerLoader(evt:Event):void {
               k.width = 500;
               k.height = 150;
          it is not tested, but this should do the trick.
