6 Replies Latest reply on Jun 22, 2010 12:26 PM by Equx02
    Car Game - Different grounds.
    Equx02
      Hi.
      I'm making a "Car Game", that will be a part of a bigger web game.
      Now I have different grounds that my car will drive on.
      Now I'm using a very long code:
      onClipEvent (enterFrame) {
      this._y += speed*Math.sin(_rotation/57);
      this._x += speed*Math.cos(_rotation/57);
      speed *= 0.8;
      if(this.hitTest(_root.wall)){
      speed = 0;
      }else if(this.hitTest(_root.wall1)){
      speed = 0;
      }else if(Key.isDown(Key.UP) && this.hitTest(_root.Grass)) {
      speed = 10;
      }else if (Key.isDown(Key.UP)) {
      speed = 15;
      } else {
      speed = 0;
      if(Key.isDown(Key.DOWN) && this.hitTest(_root.Grass)) {
              speed = -2.5;
      } else if (Key.isDown(Key.DOWN)) {
      speed = -5;
      // Turn Left (Forward)
      if (Key.isDown(Key.UP) and Key.isDown(Key.LEFT)) {
      _rotation -= 10;
      // Turn Right (Forward)
      if (Key.isDown(Key.UP) and Key.isDown(Key.RIGHT)) {
      _rotation += 10;
      // Turn Left (Backward)
      if (Key.isDown(Key.DOWN) and Key.isDown(Key.LEFT)) {
      _rotation -= 10;
      // Turn Right (Backward)
      if (Key.isDown(Key.DOWN) and Key.isDown(Key.RIGHT)) {
      _rotation += 10;
      // Turn Left (Forward, Grass)
      _rotation -= 2.5;
      // Turn Right (Forward, Grass)
      _rotation += 2.5;
      // Turn Left (Backward, Grass)
      _rotation -= 2.5;
      // Turn Right (Backward, Grass)
      _rotation += 2.5;
      I use this code so that it would go slower on "Grass" but this will be a very long code if I have multiple "grounds". Anything shorter?
      and it also needs to have to code so it does not turn when you not press UP or DOWN.
      // Kevin
        • 1. Re: Car Game - Different grounds.
          you should be using one master onEnterFrame loop.
          • 2. Re: Car Game - Different grounds.
            Equx02 Level 1
            Ok. Now I have edited the code.
            Now two questions:
            1) How about the different grounds? Do I need to set this code for every different ground?
            _rotation -= 2.5;
            _rotation += 2.5;
            _rotation -= 2.5;
            _rotation += 2.5;
            2) I have made obecjts, but I would wan't them to be more like in real life.
            Now when you hit them, the car goes a bit in to them, I would wan't it to stop right beside them or if the speed is high go back a bit.
            Samething if I press DOWN and go backwards, I can drive through them.
            // Kevin
            • 3. Re: Car Game - Different grounds.
              if you want different properties for the various "grounds", assign those properties and use those instead of hard-coding.  for example:
              var grassRot:Number = 2.5;
              var dirtRot:Number = 3;
              var roadRot:number = 4;
              var grassSpeed:Number=
              //etc
              // at the start of each loop, assign the parameters used in your if-statements:
              if(ground=="grass"){
              rot=grassRot;
              speed=grassSpeed;
              } else if(ground=="dirt"){
              rot=dirtRot;
              speed=dirtSpeed;
              } else if(ground=="road"){
              rot=roadRot;
              speed=roadSpeed;
              _rotation -= rot;
              _rotation += rot;
              _rotation  -= rot;
              _rotation += 2.5;
              // and after a pos hittest with an obstacle, return the car's position to its previous postion before impact and adjust its direction
              • 4. Re: Car Game - Different grounds.
                Equx02 Level 1
                Hi again.
                Now i've edited the code, but now I can't turn...
                speed *= 0.8;
                var dirtRot:Number = 1;
                var roadRot:Number = 4;
                var grassSpeed:Number = 10;
                var dirtSpeed:Number = 5;
                var roadSpeed:Number = 15;
                rot=grassRot;
                speed=grassSpeed;
                rot=dirtRot;
                speed=dirtSpeed;
                rot=roadRot;
                speed=roadSpeed;
                speed = 0;
                speed = 0;
                speed = 15;
                }else if(Key.isDown(Key.DOWN)) {
                speed = -10
                } else {
                speed = 0;
                _rotation -= rot;
                _rotation += rot;
                _rotation  -= rot;
                I can't turn to any direction..
                • 5. Re: Car Game - Different grounds.
                  are you defining the ground variable?  and:
                  shouldn't be in your loop.
                  • 6. Re: Car Game - Different grounds.
                    Equx02 Level 1
                    Now when I moved the code outside the loop I get the error:
                    Statement must appear within on/onClipEvent handler
