4 Replies Latest reply on Jun 22, 2010 4:05 AM by David_F57
    Log in form, working just need to expand.
    djh88ukwb Level 1
      Hello all,
      I have built a flex log in screen, but need to expand it a bit.
      At the moment it takes the values from the form (username and password) and looks in a database if those values are their and returns either true or false,  flex then looks at this value and either directs you to a new state or brings an error.
      This is all fine,  btu in my database i have added an extra field "level"  so now i have "username" "password" "level"
      basically depending on what level you are i want you to see a different state.
      Here is my code so far.
                     xmlns:mx="library://ns.adobe.com/flex/mx" width="1024" height="768">
          <s:states>
              <s:State name="State1"/>
              <s:State name="Logged"/>
          </s:states>
          <fx:Declarations>
              <mx:HTTPService id="loginService" url="login.php" method="POST" result="loginResult(event)">
                  <mx:request xmlns="">
                      <user>{username}</user>
                      <pass>{password}</pass>
                  </mx:request>
              </mx:HTTPService>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.rpc.events.ResultEvent;
                  import mx.controls.Alert;
                  [Bindable] public var username:String;
                  [Bindable] public var password:String;
                  private function tryLogin():void
                      username = usernameLogin.text;
                      password = passwordLogin.text;
                      usernameLogin.text = "";
                      passwordLogin.text = "";
                      loginService.send();
                  private function loginResult(evt:ResultEvent):void
                      if (evt.result.status == true)
                          currentState='Logged';
                      else
                          Alert.show("Login failedl", "Failure");
          </fx:Script>
          <fx:Style source="style.css" />
          <s:Panel x="387" y="242" width="250" height="146" title="Log in" dropShadowVisible="true" borderVisible="true" includeIn="State1">
              <s:Label x="10" y="25" text="Username:" fontFamily="Arial" fontSize="13"/>
              <s:Label x="10" y="55" text="Password:" fontFamily="Arial" fontSize="13"/>
              <s:TextInput x="85" y="20" width="153" restrict="a-z0-9A-Z" fontFamily="Arial" fontSize="13" fontWeight="bold" id="usernameLogin"/>
              <s:TextInput x="85" y="50" width="153" restrict="a-z0-9A-Z" displayAsPassword="true" fontFamily="Arial" fontSize="13" fontWeight="bold" id="passwordLogin"/>
              <s:Button x="168" y="81" label="Login" click="tryLogin()"/>
          </s:Panel>
          <s:Label includeIn="Logged" x="101" y="134" text="Welcome"/>
      </s:Application>
      and my php script
      <?php
      $hostname_conn = "localhost";
          $username_conn = "";
          $password_conn = "";
          $conn = mysql_connect($hostname_conn, $username_conn, $password_conn);
          mysql_select_db("videochat");
          //mysql_real_escape_string POST'ed data for security purposes
          $user = mysql_real_escape_string($_POST["user"]);
          $pass = mysql_real_escape_string($_POST["pass"]);
          //a little more security
          $code_entities_match = array('--','"','!','@','#','$','%','^','&','*','(',')','_','+','{','}','|',':','"','<','> ','?','[',']','\\',';',"'",',','.','/','*','+','~','`','=');
          $user = str_replace($code_entities_match, "", $user);
          $pass = str_replace($code_entities_match, "", $pass);
          $query = "SELECT * FROM usernames WHERE username = '$user' AND password = '$pass'";
          $result = mysql_query($query);
          $logged = mysql_num_rows($result);
          if ($logged == 1)
              echo "<status>true</status>";
          else
              echo "<status>false</status>";
      Now i know i need to epxnad both, so that the php returns their level, but i am getting a bit stuck, any help ?
        • 1. Re: Log in form, working just need to expand.
          djh88ukwb Level 1
          Ok, i have expanded on this, but getting an error=[
          I have changed my php code to the following
          <?php
              if ($logged == 1)
                  echo "<level> ".$result['level']." </level>";
              else
          Added a <level> </level> on the echo's, and this is supposed to pull the value in the database under the field "level"
          I have also added this to my flex app
                          if (evt.result.status == true && evt.result.level == 'candidate')
                          else
          Although when i try to log in, it brings the failed message =[
          ANy reason why ?
          • 2. Re: Log in form, working just need to expand.
            David_F57 Level 5
            hi,
            this is an example using zend services
               xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:valueObjects="valueObjects.*" xmlns:usersservice="services.usersservice.*">
            <fx:Script>
            <![CDATA[
            protected function button_clickHandler(event:MouseEvent):void
            checkUserResult.token = usersService.checkUser(email.text,password.text);
            protected function checkUserResult_resultHandler(event:ResultEvent):void
            if (checkUserResult.lastResult != null)
            currentState="success" ;
            ti.text="welcome back, "+ event.result.UserName;
            else
            currentState="fail";
            protected function button1_clickHandler(event:MouseEvent):void
            currentState="State1";
            </fx:Script>
            <s:states>
            <s:State name="success"/>
            <s:State name="fail"/>
            </s:states>
            <fx:Declarations>
            <valueObjects:Users id="users"/>
            <usersservice:UsersService id="usersService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
            <s:CallResponder id="checkUserResult" result="checkUserResult_resultHandler(event)"/>
            </fx:Declarations>
            <s:Panel width="350" horizontalCenter="0" verticalCenter="0" title="User Authentification" includeIn="State1">
            <mx:Form defaultButton="{login_btn}" verticalGap="10" width="100%">
            <mx:FormItem label="Email">
            <s:TextInput id="email" width="240"/>
            </mx:FormItem>
            <mx:FormItem label="Password">
            <s:TextInput id="password" width="121"/>
            </mx:FormItem>
            <s:HGroup width="100%" paddingTop="2" paddingLeft="2" paddingBottom="2" paddingRight="2">
            <s:Button label="login" id="login_btn" click="button_clickHandler(event)" width="100"/>
            <mx:Spacer width="100%"/>
            <s:Button label="cancel" id="cancel_btn" click="button_clickHandler(event)" width="100"/>
            </s:HGroup>
            </mx:Form>
            </s:Panel>
            <s:Button includeIn="fail" y="291" label="Go Back" horizontalCenter="0" click="button1_clickHandler(event)"/>
            <s:Label includeIn="fail" y="239" text="No Such User" horizontalCenter="0" fontSize="24" textAlign="center" color="#B11C1C" fontWeight="bold"/>
            <s:TextArea includeIn="success" x="500" y="147" id="ti"/>
            </s:Application>
            php:
            public function checkUser($email,$pass) {
            $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename where EMail=? and Password=?");
            $this->throwExceptionOnError();
            mysqli_stmt_bind_param($stmt, 'ss', $email, $pass);
            mysqli_stmt_execute($stmt);
            mysqli_stmt_bind_result($stmt, $row->ID, $row->Level, $row->UserName, $row->EMail, $row->Password);
            if(mysqli_stmt_fetch($stmt)) {
                  return $row;
            } else {
                  return null;
            David.
            • 3. Re: Log in form, working just need to expand.
              djh88ukwb Level 1
              Whats the difference between this, and what i was using  ? m
              Im sorry ?
              • 4. Re: Log in form, working just need to expand.
                David_F57 Level 5
                hi,
                Its muchness over muchness(except amf is better than http request ), I just return the record and don't have to do much at the client end. I just added the php to show where it fitted in the client side of things.  PLus It was just for a comparison, the only difference that needs to be added is the switch statement for states.
                so on return
                switch(level)
                case 0: currentState = "level0";
                             break;
                case 1: currentState = "level1";
                             break;
                case 2: currentState = "level2";
                             break;
                case 3: currentState = "level3";
                             break;
                default : currentSate ="denyAccess";
                David.
