3 Replies Latest reply on Jun 22, 2010 6:18 AM by miguel8312-3K1O2b
    syntax !variable
    miguel8312 Level 3
      i often time see syntax like this...!variableName can someone please tell me what this stands for... it seems shorthand for something but im not sure i get it sorry for my ignorance your reponse is greatly appreciated.
      Miguel
        • 1. Re: syntax !variable
          David_F57 Level 5
          hi,
          ! = is not
          so if myTest = false;
          !myTest  evaluates to true (basically the opposite)
          if (myTest == false) is the same as if(!myTest)
          David.
          • 2. Re: syntax !variable
            BhaskerChari Level 4
            Hi miguel8312,
            As David said in his earliar post hope you have understood its significance...and I just want to add few more points
            we can also use ! symbol the follwing way...
            var someVariable:String;
            if(!someVariable) is equivalent to using  if(someVariable == null)
            var someVariable:String="";// empty string
            if(!someVariable) is equivalent to using  if(someVariable == "")
            Bhasker Chari
            • 3. Re: syntax !variable
              miguel8312-3K1O2b
              thank you both i really appreciated this was killing me I kept seeing in others actionscript code but i didnt want to assume... Thank for your replies and sharing.
              Miguel
